Aug-16-2017 07:27 PM
Aug-18-2017 08:46 AM
Grit dog wrote:
Find a local plastic shop and see about getting a sheet of HDPE or umhw.
That or aluminum.
If it's not needed to hold anything up structurally then I'd also consider using the plastic/fiberglass paneling used in shower surrounds, from the hardware store. It would be more prone to cracking but it's cheap and easily accessible.
Aug-18-2017 08:45 AM
cewillis wrote:
Wow -- that does not look good. I think I'd be tempted to get a big piece of diamond plate aluminum --assuming there is a good structure to fasten it it to.
Aug-18-2017 08:38 AM
Aug-18-2017 08:05 AM
Aug-17-2017 09:05 PM
Aug-17-2017 08:36 AM
RamblinAnne wrote:54suds wrote:
heres another
the new plywood you see in the first picture is floor and sidewall reinforcing added to stop cabinet & wall seperation and rear sag on a 10.5 model the second is a 10.11
Yes! I definitely need to do this. I did notice a bit of separation the last time I had the camper off the truck. Im sure it's normal but the sagging really freaks me out so I think reinforcement totally needs to happen.
In the first pic from previous post.. I'm not able to tell which way I'm looking at the tanks. Is that the rear bumper in the top of the photo? And I'm guessing that smaller tank is the black and the larger is grey? And then this is the fresh water in this second pic? Just trying to figure out tank placement.
Aug-17-2017 05:22 AM
Aug-16-2017 10:51 PM
RamblinAnne wrote:bighatnohorse wrote:
Your signature says the camper is a Bigfoot. isn't that a one-piece underbelly?
If you dump the tanks before taking it off the truck, it should not be a problem.
But I'm a little confused - if it's already on the truck, how can you tell that it's sagging?
Anyway, dump the tanks before using the camper off-truck.
So I noticed a bit of sag the last time I dumped my tanks. There's about a foot and half of camper length that sticks out past the rear bumper. (The part where I connect my sewer hose). The underbelly is a few pieces, last I remember. Definitely more than one.. I think 3 but maybe just 2. I'll snap some pics when I get it off of the truck tomorrow.
Aug-16-2017 10:25 PM
Aug-16-2017 09:52 PM
54suds wrote:
heres another
Aug-16-2017 09:37 PM
Aug-16-2017 09:36 PM
Aug-16-2017 09:31 PM
54suds wrote:
tanks in BF's are hung using seat belt type straps that allow the bellies of the tanks to sag will try to post pix tommorow my intege:rnetling tonight is super slow
Aug-16-2017 08:44 PM
Aug-16-2017 08:39 PM
