Scangauge - ? tranny temp, 06 F250, 5.4
MR_MAC
I have a SG II, on a 2006 F250, 5.4, all works well, but can it rec. tranny temp also on this truck? anyone doing this let me know
ROBERT L MC INTYRE
8 REPLIES 8
MR_MAC
"I GOT IT" Used the codes (CANSF) Desert Captain gave me, Thanks all
for your help.
Rob
ROBERT L MC INTYRE
RWDIII
I don't know,how to use it,one for the other
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
lbrjet
Shouldn't the cylinder head temperature be about the same as the oil temp?
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
RWDIII
I have a 2006 F150 and the codes from the website worked for me
I also programmed it for slip in trans.Aftr Desert Captain they must have fixed it.
am I the only one disappointed that they cant get a code for oil temp in the 5.4?
Desert_Captain
I have a 2006 F-150 with the 5.4L. When I got my SCII They had to look up the codes
for TFT and here they are:
TXD: 07e0221674
RXF: 046200000000
RXD: 3010
MTH: 000100080000
These codes got me TFT and should work for you. The codes on the website did not work but one of their engineers came up with these. :C
tvman44
Works on my '02 with 7.3L diesel after programming in the X code. ๐Ÿ™‚
Papa Bob
Husky 16K hitch, Tekonsha P3,
lbrjet
My 2010 uses the Ford CAN codes.
SFVdave
Go to their website and look up the X code. Then followi the instructions for entering it. Good luck. Works on my SG2 on ford e 350 v10
