Screen Removal - How To?
Tizi
I want to clean the windows in my Northern-Lite camper. How in the heck do those come out???
2008 Dodge Ram 2500 QC 4x4 - HEMI
2007 Northern Lite 10.2 RR
Tizi's Transformer by Whazoo
6 REPLIES 6
jimh406
Make sure there arenโ€™t plastic inserts in the tracks if you think your screens canโ€™t be removed. Itโ€™s non-obvious, but they are almost certainly there.
K_Mac
I see yours windows are the older style most of that age have, all my old campers were similar, there usually spring loaded, just try and coax the top and bottom would be my guess in your model, that's what I used to do till I figured out which side held the spring. My pass through is the only one that's removeable now on the newer N.L.,the others retract into their frame's.
mike_kellie
Spring type clip on mine. slightly press down or up to compress and out they come
2015 Host Mammoth triple slide w/ TorkLift Fastguns
2015 Ram 5500 SLT cab & chassis with Douglass 9' utility body
ScottG
Often times the screens will just slide out of the way.
Kayteg1
Picture?
Almost each manufacturer has different system, so there is no 1 shoe fits all.
jimh406
Mine has a little plastic piece that slides out. Then, the screen will come out.
