Shower Leak
Grodyman
Anybody have their shower leak into the basement at the drain? This seems to be happening on my Lance 830. Wondering if the drain pipe to the gray tank loosened or cracked? No cracks in the pan, and it is definitely coming from the location of the drain, and not around the toilet seal.
What would be the best way to look? Remove toilet or unscrew the drain? Any suggestions would be appreciated.
Gman
2017 F150 CC/5.5' 4x4 3.5 Ecoboost/3.55
2018 Passport Ultra-Lite 153ML
3 REPLIES 3
Houston_Remodel
The usual culprit is the seal around the drain to the pan. Start there then look at the pipe joints.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
jimh406
Since you have a Lance and they have detailed manuals online, I'd take a look there. You might also give Lance a call.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
Kayteg1
My camper has a door outside that will open area under shower pan.
I had to dry out the compartment last week.
The inside connector for outside shower drip slowly, what was not visible from inside and water drop via the hole in the main floor to the basement.
