Slideout Not Opening
SETenn
I attempted to open my slideout just before taking my camper to Camping World to get the awning replaced about a month or so ago and all it would do is make a buzzing noise. When I took the trailer to the shop I had them to check the slide while they had it. Well, they called a few days later and said it was working fine, no need to replace anything. I checked it when I picked the trailer up and it was working. We returned from a camping trip today and the same thing happened. The buzzing is coming from a circuit board underneath the kitchen cabinet.
Has anyone else had this issue? I am trying to figure out if it is the switch for the slideout or if it is actually the circuit board.
Any assistance would be greatly appreciated.
5 REPLIES 5
Nmomoct28
We just opened ours at a rest stop. First time on the road with it and panicked when it wouldn't retract. We had to level the trailer before it would work.
PaYahoo101
Every once in a while mine won't extend. If I take the hand crank and just get it started, it will then work electrically.
brirene
Houston Remodeler wrote:
Turns out there was a loose connection. Sometimes it worked, sometimes it didn't.
That's where I would check first. Get to the motor and check all the connections.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Houston_Remodel
Who made the slide out? The manufacturer should have tech support.
We had the same symptoms. Turns out there was a loose connection. Sometimes it worked, sometimes it didn't.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
100ton
My GUESS is that the buzzing sound is due to a defective relay switch (solenoid). ????
'05 Ford F250 Crew Cab, PSD, 4X4, Short Bed, Camper & Tow Package, Limited Slip Differential
'05 CrossRoads, Cruiser 29RK
PullRite 16K SuperGlide
