Slideout override
jhubbard
Hi Guys,
My slide out wont slide in and i have replaced the switch but nothing happens. The battery is fully charged. I just need to manually override and slide in but cant find the manual override. I have a Keystone 2000 Springdale lite 485. The slide out system is a Dewald Hydra-Sync System. Does anyone know how i can manually override this?
10 REPLIES 10
Retired_JSO
Some have a hex head right on the pump to manually pump fluid using a drill.
Rumtan
I had to youtube mine to find out it was up on the right side behind the facia
2013 Keystone Passport 2100RB
2015 F150 ecoboost
Fish-O-Holic;)
Junket
Mine has a fuse just past the main battery disconnect.Might check that.
Ken
2005 Dodge Cummins 610 325Hp 3.73 Auto
2016 Wildcat 26FBS
Go Fast 66 Cobra replica 500+HP Richmond 6sp
2015 Jeep unlimited
23ft. Striper boat
Big_Love
There are so many different slide mechanisms, that you will probably need to call the manufacturer or your dealer to get an answer.
To manually operate my slide, the instruction requires me to cut out a window in the trailer's underbelly covering and use a socket wrench to turn the motor after applying a 12v current to a switch to deactivate a locking mechanism!
Make sure that the slide fuse located near the battery is intact and that all slide wiring connectors are in good shape.
RedRocket204
Another item to check... my slide switch was wired where the ground was off of the chassis and that connection was extremely loose. I removed it, cleaned it and then tightened it back down and it started working properly again.
But as other's have noted, my manual slide over-ride is also on the opposite side of the slide and requires the removable crank arm to bring it in manually.
I love me some land yachting
JoeTampa
Also check the fuse. That got me once.
2006 Keystone Cougar 243RKS (First trailer)
2016 Jayco Jay Flight 32BHDS (Traded in)
2016 Jayco Jay Flight 33RBTS (Current)
2006 Chevy Silverado 2500HD 4WD 6.6L Duramax Diesel (LBZ)
Blue Ox Swaypro 1500 WDH
Prodigy P2 BC
Amateur Call AB2M
Bears_Den
You may want to check between the battery and the slide for a selenoide and see if you have a loose connection. I ran into the same problem only to find out I had a loose wire. My selenoide was located on the front tongue frame between the battery and the slide. What a relief it was to find out it was something so simple.
2014 Kodiak 279 rbsl
2017 Ford F-150 King Ranch V8
Equalizer hitch
Ford integrated brake controller
2004 Travel Lite 23S Hybrid Travel Trailer ( previous trailer )
1998 Viking Popup ( previous trailer )
No substitute for experience
phone_man
My override is in a small cut out in the underbelly by the entrance steps. Once you open it you have to insert a socket set in there. Mine is a Primetime Lacrosee.
bguy
You should have a large handle with your tools that came with the trailer. It'll look similar to the stabilizer handle. Then you'll have to find the access hole in the trailer body. Some are on the same side as the slide. Mine is on the opposite side. It'll be 1-1/4" or around that and have a plastic collar typically. Insert the handle and crank her in. I don't imagine it would be any good to try and rush it in.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
jhubbard
Hi Guys,
