Small A/C
campigloo
I may be looking for something that doesn’t exist. I want a small, 5000 btu or less, roof mount ac. All I want to do is cool the bedroom. I want one that a 2000w generator will power.
Any ideas?
Thanks!
23 REPLIES 23
time2roll
I assume a 9200 would run off a 2000 generator in most conditions.
campigloo
CoolAir RTX 1000
Dometic
Farm_Camp
campigloo wrote:
Thanks y’all. I think I may have found it.
Truck a/c!
Domestic makes a 1200W unit that runs off of 24v dc. It even has a remote, so it’s fun too! I’m waiting on a response from them to see what they think. Hopefully it will cool without the vehicle moving.
That sounds like a awesome idea - very creative! If you don't mind post a link to the unit you are considering?
TV: 2010 F250 XLT 4X4 SC SB 5.4L 3.73 - "The Blue Monster" (2013-2018) Traded at 100K
TV: 2017 F250 XLT 4X4 CC SB 6.7L PD 3.31 - "The Silver Streak"
TT: 2014 Starcraft Autumn Ridge 329BHU
Our Story...
Places we've camped
campigloo
Truck a/c!
Farm_Camp
It takes up a good chunk of floor space: I have a 7,000BTU (EDIT: 8500BTU) portable AC that stands on wheels and vents out through a window with a hose. My 2000w Inverter generator can run it, but, can NOT start it up when it is in ECO mode.
I think you can get those in smaller BTU models that a 2000w would run and start in ECO mode... I use mine at the storage lot on hot days along with my gen if I need to do work inside and it is perfect for my need. It would work if I were boondocking and willing to run my generator with eco mode turned off. But - It takes up a fair amount of room as stated.
EDIT 2: If I read your reply to Charlie right this solution might work if you were willing to give up the floor space and make a more secure way for it to vent to the outside. A buddy of mine used plexiglass with a hole cut in it for the hose because the supplied window adapter would not securely fit in the window he wanted to use.
Our Story...
Places we've camped
campigloo
Thanks Charlie. Yes I have a window I can stick it in but I was hoping to be able to use the gen so I can run it ahead of stopping for the day. The bed gets so hot it takes forever to cool it down.
newman_fulltime
Smallest i know of is a 9200 polar cub ac
CavemanCharlie
Is there some way you could use a window unit in the bedroom ?
I had a TT once that I had to use one of them in.
I added a cargo door to the side of the TT and a shelf underneath of it.
When going down the road the AC would set in the shelf inside the TT with the cargo door closed.
When at the campground I would open the cargo door and set the window unit into it.
Plug it in and I was good to go.
SoundGuy
Yep. :W
Any ideas?
Nope. About the smallest roof mount A/C is ~ 9000 BTU.
2012 Silverado 1500 Crew Cab
