Smallest AC that a Honda 2000 will Run?
Snowy_Bird
Just sniffing around for AC units to eventually install on our NL which we will be getting in Feb.
I purposely did not order one, factory installed as I have heard (from more than one source), that manufacturers buy AC's by the truck load and of course, from whomever gives then the best price.
I don't think the manufacturers really give too much consideration as to whether a Honda 2000 will run their chosen AC.
I figured we would get a Polar Cub 9200, but now I'm reading that the newer ones are using more power than the older ones?.
Does anyone out there have a less than 2 yr old PC 9200 that they have run off of their Honda 2000 with no problems? Or anyone know of a small brand new model that will work?
22 REPLIES 22
twodownzero
Mine runs my coleman just fine as well. My camper has neither oven nor microwave so no concerns there.
wsdepa
My Polar cub 9.2 is eight years old and I have run it on my EU2000 at 7,000 feet with no problem.
2006 F-350 S/C 6.0 DRW 4x4 3.73, 2005 Lance Max 981, most options. Camped 49 states and all Canadian Provences(cept Labrador). 100,000 miles and 500 plus nights of TCing.
http://truckntravels.blogspot.com/
trailgranny50
We just installed one on our 1990 hard side Shadow Cruiser in June. The Honda 2000 runs it fine here in Oklahoma. The humidity doesn't seem do make any difference except in the run off water from condensation. We knew going in the AC and microwave wouldn't run safely at the same time. No biggie. What did become an issue was that the outlet provided for the microwave was wired in with the service to the AC for some strange reason, and not at the breaker, in the wall somewhere. It's an old 45 amp converter set up. We simply moved the microwave over to the cabinet closer to the bed and plug it into the receptacle there that is on a separate breaker so that when on shore power we can run them both. Our older Polar Cub on the horse trailer ran fine, the same as the new one, on a Honda 2000 genny as well. The new ones are supposed to be even more energy efficient so I don't see a problem. However that seems to be the comfort limit for the generator as the A frame hard side camper we had for a time had a 10,500 btu AC/heat pump combo and the Honda didn't like it very much. Anyone needing a really cheap 9200, new PM me.
2004 Chevy 3500 Duramax all stock
1990 950 Shadow Cruiser Hard side multiple add-ons
Ancient Valco 10'x5' John boat
2011 Toyota FJ Cruiser Trail Team
One-eyed Trail Horse and one horse trailer
Rocky, Annie, Muffie traveling Fur Babies
anutami
Wish I could help out, and would be able to provide feedback, but I took delivery of my new TC in May and ordered the new coleman mach 9200. They instead put the coleman low pro 13.5 unit on. The 13.5 WILL NOT run off a honda 2000. (It will at sea level where I tested it out at the dealer and have beach camped a few times) Unfortunatly I bought my TC out of state. I talked the dealer into mailing me the correct unit only to have it lost in the mail and still waiting on the pending claim with UPS!
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
wintersun
An AC unit's compressor motor draws 2-3 times as much on startup. The 2000 Watt Honda or Yamaha will handle a 9.3k but not a 13.5k btu AC unit. With some AC units the replacement of the stock capacitor will assist with the startup demand.
The smaller the AC the more efficient it will be in removing the moisture from the air inside the camper. Higher btu AC units will cycle off to soon.
Carb_Cleaner
We have a Polar Cub 9.2 that was installed by the dealer. The reasoning was that it can run off a Honda 2000 and it has a lower profile than the A/C unit offered by the manufacturer. We took delivery of the TC 11 months ago, so I assume it's a newer unit. Our Honda EU2000 Companion runs the A/C, but if we want to use the microwave, we temporarily shut down the A/C. Our experience with the Honda 2000 and PC was relatively near sea-level, somewhere between 500' and 1000', boondocking on the Shenandoah River in July. Nice and humid. We spent a week in The Keys this past August, connected to shore power, and the PC 9.2 performed wonderfully. Staying in Daytona for a couple days, the temp. was 100 degrees with a "humiture" of 120 degrees. We were driveway camping at my sister's and there was zero shade. The PC 9.2 kept us very comfortable.
Full disclosure, I've added some upholstery foam for insulation in the bath skylight and a few windows that didn't have storm windows (escape window in the cab-over, pass-through window below the cab-over and rear door window).
'13 F250XL SC gas 4x4 8', Camper & Plow packages, StableLoads, LT285/65R-18 Goodyear Wrangler A/T Adventure, 18x9 Ultra Motorsports "Phantom" wheels
'12 Wolf Creek 850 TC Coleman Polar Cub 9.2k A/C, 90 watt solar, dual propane & batteries, Maggie Rack
voodoo101
Keep in mind that they lose about 3% power for each 1000 feet of elevation. Can make a big difference in the mountains. 15% loss just at Denver.
Big_Katuna
I have read here a poster runs a Coleman Mach 3 PS (Power saver) on a 2000. Specs look like it should.
clicky
My Kharma ran over my Dogma.
