Apr-05-2018 11:44 AM
Apr-10-2018 04:38 PM
Apr-09-2018 02:32 PM
Apr-09-2018 07:54 AM
Oscar P wrote:
Now I'm really confused. I am following you on your explanation, the reading I have done on the BW 6406 says that it will allow you to run on either 12v or 120v by flipping a switch, but does not charge the batteries when hooked to shore power. Before I get too involved in this things, y'all please correct me in this.
***Tried to attach a picture to help out, but can't figure it out.***
Apr-08-2018 06:03 PM
Apr-08-2018 02:52 PM
Apr-06-2018 08:07 AM
Apr-06-2018 07:57 AM
hedge wrote:
You still have your terms mixed up.
- Converter changes 120v to 12v, It also usually serves as the 12v and 120v distribution point having breakers for the 120v AC and fuses for the 12v DC side. Never seen a converter that doesn't charge the batteries.
- Charge controller is the piece that sits between solar panels and the batteries.
- Inverter takes 12v DC and inverts it to 120V AC, this is not usually an OEM installed piece.
Apr-06-2018 07:36 AM
Apr-06-2018 07:06 AM
Apr-05-2018 07:03 PM
2oldman wrote:
I think he's mixing up terminology.
Oscar P wrote:
My converter in the camper is a BW Model 6406, which apparently means it will allow me to run off of batteries for my electrical needs, but will not charge the batteries.
Apr-05-2018 01:45 PM
2oldman wrote:
I'd suggest you start by reading this: 12v side of life.work2much wrote:I didn't see anything in his post indicating he needs an inverter. I think he's mixing up terminology.
As far as inverters you need to calculate your max draw and size. 1000 Watts should be more than enough for your battery capacity..
Apr-05-2018 01:37 PM
Apr-05-2018 12:51 PM
Apr-05-2018 12:46 PM
