โOct-31-2015 05:36 PM
โNov-03-2015 03:54 AM
โNov-02-2015 01:13 PM
mkirsch wrote:
Assuming you get enough sun and keep the snow off the panels. Even then you're going to need a lot of solar to keep up because its efficiency is way down with the sun low in the sky and only out for about 8 hours a day.
โNov-02-2015 07:41 AM
Golden_HVAC wrote:
There are solar panel controllers with dual outputs for RV use. Basically it will send most of the power to battery #1, but when it is full, it will divert to battery #2 until it becomes full and it shuts off, or if battery #1 drops below say 12.9 volts, it will go back to charging battery #1 until it reaches say 13.4 volts, then will switch to battery #2 until both are at 13.4, then it will shut off.
Good luck,
Fred.
โNov-02-2015 03:49 AM
โNov-01-2015 04:15 PM
โNov-01-2015 10:27 AM
โNov-01-2015 03:22 AM
โOct-31-2015 10:45 PM
Porsche or Country Coach!
โOct-31-2015 08:44 PM
โOct-31-2015 07:22 PM
โOct-31-2015 06:26 PM
โOct-31-2015 06:10 PM
