โJan-10-2015 08:27 PM
โJan-20-2015 06:44 PM
โJan-20-2015 05:42 PM
GoPackGo wrote:
I have a couple suggestions for you, based on the options I ordered or didn't order on my 2013 F350 diesel dually 4x4 crewcab longbed. I fulltime so your mileage may vary.
1. If you have any thoughts of getting a 5er at some point, then I suggest that you get the Ford 5er prep package. In addition to the predrilled holes in the bed, it includes an additional umbilical electrical plugin in the bed - now you will have a total of two to choose from. You will get a set of plastic pucks to cover the holes if there is no hitch installed.
2. I got the Ford spray in bed liner. It seems to be a quality product and has held up well. Part of my thinking was that Ford would do all the prep work and would make sure the spray would coat all the edges of the holes that were cut as part of the 5er prep package. I have never run any kind of bed mat in my trucks. What happens when you get water trapped under it ???? RUST !
3. I did not get the dual alternator package and have not missed it. I have the Platinum model with diesel glow plugs, heated seats, running lights, etc and no problems. I believe the diesel option gets you a larger alternator then comes standard on a gas truck.
4. I agree that the Fx4 package is a joke. Check out what's really included in the package. I didn't want the crappy shocks from the package so I just ordered the skid plates separately (cheap)and put Bilstein 5100s on the truck right after I took delivery. Guess I'll have to live without the big decal that tells the world I drive a 4x4 truck.
5. I have the 3.73 rear end but that was the only one offered with my setup. I tow 14,000 pounds (gross) and all I can say is that towing is a dream. I would never want a lower (numerically) gear ratio. The gear selector never moves out of 'D'. This thing is a beast and doesn't seem to care how high the mountains are. I'm turning about 1600-1700 RPMs (maximum torque) at about 58-60 mph. And I can still get over 20 mpg on the highway when not towing.
6. I also got the optional upfitter switches. It's a cheap option ($125 ??) and will be handy if you want to wire up additional lighting, or maybe a fuel transfer pump when you get that auxiliary fuel tank in the bed (see my note below).
* Something to remember is that you get a significantly larger diesel fuel tank with an F350 longbed truck. I believe the tank is 26 gallons on a short bed truck and 37.5 on a longbed.
Tim
โJan-20-2015 05:00 PM
โJan-20-2015 08:17 AM
4x4ord wrote:Lynnmor wrote:
I got the plow package with the 3.55 gears and heavy alternator. Don't want the 20" wheels as they are just for show; no go. The larger wheels would make the gearing about the same as the 3.31.
Both those reasons are why I like the 20 inch wheels. I have absolutely no desire for a different final gear ratio. Why would anyone need a lower speed gear ratio than 3.31 in a srw pick up truck with a first gear ratio of 3.97 and 800 or more lb ft of torque engine?
โJan-20-2015 06:11 AM
โJan-20-2015 05:23 AM
โJan-19-2015 04:01 PM
skyhammer wrote:
When I bought my 2011 DRW, there were 3 ways to get the heavier front springs.
The camper package, snow plow package and the FX4 off road package.
All Ford diesels from 2011 up have an exhaust brake, the 2015 has a better one, along with a new turbo and you have more control over the exhaust brake.
I have dual alternators and would not like to be without them. Depending on your options you may have to get the heavy duty dingle alternator.
If you get the supplemental heat option(worth the money), you will need at least the heavy duty alternator.
At start up(especially on a cold morning) I have a heavy electrical load.
You may have to wait for the glow plug light to go off before starting,which sucks juice, both seat heaters going, headlights, plus the over 30 lights the DRW has,supplemental heat, which is about 1200 watts, you have no control over when it goes on or off.My air compressor for air bags etc., usually starts.
So on start up, I can be drawing over 200 amps easily.There are many other electrical draws that I haven't mentioned.
โJan-19-2015 03:14 PM
โJan-19-2015 02:29 PM
โJan-19-2015 12:19 PM
โJan-13-2015 02:14 PM
โJan-13-2015 01:52 PM
Bedlam wrote:
I remember when my extended cab short bed 4wd diesel with camper package was going to be all I needed. Ten years later and I'm in a class 5 chassis cab crew that could haul my previous truck as payload. We're looking at the triple slide truck campers with side entries and dry baths now...
You will find some nice short bed truck campers with a slide that can be handled by a SRW (about 7000 lbs on the rear axle). If you decide to do this and tow heavy behind you at the same time, I can even point you to the upgrades that will work on this truck.
โJan-13-2015 01:10 PM
โJan-13-2015 12:48 PM
4x4ord wrote:smcrea wrote:4x4ord wrote:smcrea wrote:4x4ord wrote:4x4ord wrote:
The camper package is of no significance on the diesel F350 because it already has the heavy front axle and rear stabalizer. The 20" tires are rated for more weight than are the 18" tires. (3750 lbs per tire for the 20" and 3640 for the 18" tires) The 20" rims will give you a little more "stability" due to their lower profile. 20 wheels also provide for a little lower rpm at highway speed if you are getting the 3:55 rear end. This lower rpm will equate to a little better fuel economy. If you want the best fuel economy you need to go to the 3:31 rear axle ratio which will require you get 18" wheels.
I made a mistake here. The 4x4 F350's front axle weight rating range from 4400 lbs to 6000 lbs depending on wheel base cab configuration and engine. The F350 diesel 4x4 crew cab has a normal computer selected front axle weight rating of 5600 lbs regardless of tire size. Selecting camper package should up grade the front axle rating 1 level higher than the normal computer selected axle which would be 6000 lbs which is the same springs as the snow plow option.
Thanks for checking up!
Listening to you experts it really does look like going with the camper package is the safest option. Especially as we are buying this type of truck specifically because it's a towing beast!
Bottom line is that no matter what type of RV we get in the future... towing now with our 28' Travel trailer or upgrading to a a 5th wheel as the kids get bigger or downgrading later on to a camper shell after the kids have left home. I want this new truck to be able to do anything I throw at it!
Some folks have said that for my 27' TT then this is over kill. Which is absolutely true!.. but I NEVER want to be limited by my truck when selecting an RV.
A little additional information for you: my F350 4x4 crew cab has an empty (driver in but no passengers or camper) front axle weight of 4900 lbs. To stay within my gvwr I could only carry 3100 lbs of camper and passengers. This number would be the same regardless of whether I have the camper package or not. The question that needs answering is ..... How much weight would a 3100 lb camper put on my front axle? Very likely 700 lbs would be close. So what I am getting at is that, if you see yourself carrying a camper heavier than 3100 lbs maybe a dually is something you might want to consider buying rather than being concerned about the camper package.
I certainly considered a DRW but after much thought I considered that the 'bang for the buck' isn't worth it. I'm sure that others will disagree but my feeling is that when 'on site' the Tow Vehicle becomes your family car for sight seeing. So physical size is an issue. This same reason is why I got the shorter bed.
I feel the same way. I tow very heavy loads with my short box SRW (30,000 lb trailers at times) but when I am empty I don't want a dually. The thing for you to consider is that if you want a truck to tow your fifth wheel around the SRW short box is perfect and you don't need or even want any stiffer springs on the front than the standard 5600 lb springs. If you decide to get a slide in camper some time down the road you will be quite limited in what kind of camper you get if you only have a SRW short box so again I wouldn't put much priority on the camper package. I think by the time you load up a high quality, nice size camper with all your gear you could be pushing 5000 lbs and that is a load for a dually.
