โAug-13-2015 02:58 PM
โAug-31-2015 07:27 PM
โAug-31-2015 06:23 AM
โAug-29-2015 03:56 PM
โAug-17-2015 07:31 AM
โAug-17-2015 05:20 AM
Calicajun wrote:
Great to hear that your RV won't let the rim of a blown tire not drag the ground. Wish my TT would do that but it doesn't. ๐
โAug-16-2015 04:35 PM
โAug-16-2015 10:15 AM
Atlee wrote:
Then you must want to get on the next planet when a triple axle is making a sharp turn. ๐mosseater wrote:
The only thing I know for certain is that when I'm near one while it's taking a sharp turn, I have a primal need to get farther away. That's a lot of stress, whether you feel good about it or not.
โAug-16-2015 08:33 AM
8iron wrote:69 Avion wrote:icanon wrote:
Just a thought. Can someone get their TT modified to have the 'spread axle setup'? Is it ok to do so if done at truck/trailer suspension repair shop? Or is it Not recommended?
Almost anything can be done for a price. Why change a setup that has less scuffing and should have been built with a heavy enough frame from the factory for proper support?
Check out large trailers on semi trucks. The rear tandem duals are close together on "most" of the trailers. They will spread them out for special loads, but it is relatively uncommon.
If spreading the axles are such a great idea, why not spread them out another foot or two. If wide spread axle placement is "really good" than futher apart should be "even better"!!! It isn't.
These manufacturers that use the wide spread axle placement are probably doing it to spread the load on their frame. It saves them money on a frame that may not have enough support with the axles close together.
Any facts to support any of your statements? I toured the Crossroads factory a few years ago and was told the Lippert frames were made of the same materials just longer or shorter per spec. Hence the shorter TT's generally having a higher CCC than the longer ones.
โAug-16-2015 02:51 AM
โAug-15-2015 06:45 AM
โAug-15-2015 06:25 AM
โAug-15-2015 05:50 AM
โAug-15-2015 04:12 AM
โAug-15-2015 04:00 AM
Terryallan wrote:icanon wrote:
Who makes these spread axle setups?
they are on "some " Forest river, and "some " Jaycos, and "some" of just about every brand.
I'm guessing they are Dexter axles
