Aug-10-2014 10:36 AM
Aug-10-2014 05:57 PM
downtheroad wrote:
My rule of thumb has always been to pick a bar size to match 12% of the trailer's GVWR.
Aug-10-2014 02:07 PM
Ron Gratz wrote:Aluminum Siding wrote:The weight rating of the WD bars should be based on how you plan to use the bars.
---Now I have a new 250 and it doesn't feel a thing. 70% of the time my water tank is empty but we do dry camp a couple of times a year. Do you think I should upgrade to a set of 1200 bars. Just trying to keep undo pressure off the truck.
For your truck, Ford specifies that the WDH should be adjusted to eliminate approximately 50% of the front end rise.
This means the WD bars would be loaded only to approximately 50% of the load required to eliminate 100% of front end rise.
If you have a 1200# tongue weight and your goal is to eliminate only 50% of the rise, you could get by with 600# bars.
Your current 1000# bars are more than sufficient to eliminate 50% of the rise.
Ron
Aug-10-2014 01:05 PM
Aug-10-2014 01:04 PM
Aug-10-2014 12:44 PM
Aug-10-2014 11:17 AM
Aug-10-2014 10:49 AM
