โNov-20-2019 02:45 AM
โNov-25-2019 04:57 PM
โNov-25-2019 04:10 PM
Me Again wrote:spoon059 wrote:
โNov-25-2019 02:24 PM
spoon059 wrote:rhagfo wrote:spoon059 wrote:
Can't help but notice you cherrypicked the most EXPENSIVE tire (20") to compare to the cheapest tire (17"). My 18" tires aren't nearly as expensive as those 20's.
That is because most DRW have 17" tires.
I understand why he gave prices for 17" wheels. If you look at the CAPITALIZED word, I emphasized why he chose the MOST EXPENSIVE ALTERNATIVE to make his argument. I would venture a guess that most SRW HD trucks have 18" wheels, not 20's. Further, I would venture that the truck buyers that are buying higher models with 20" wheels aren't as concerned with tire costs.
Thanks though.
โNov-25-2019 12:47 PM
โNov-25-2019 07:35 AM
โNov-25-2019 06:13 AM
โNov-25-2019 06:11 AM
larry barnhart wrote:Cummins12V98 wrote:larry barnhart wrote:Me Again wrote:
The majority of TowHaulers I see running around the freeways of the greater Phoenix area are being towed by headlights high SRW trucks.
What others do doesn't mean much to me just to some folks.
chevman
It should as these people are a danger to others.
really commenting on the SRW idea but agree with you.
chevman
โNov-24-2019 11:18 PM
Cummins12V98 wrote:4x4ord wrote:
How many miles do you dually guys get out of a set of tires. I only get 40k miles out of my 20 inch factory Michelins.
Current Michelins at 30k have 1/4" tread left all around. Last set only made it 40k total. I did get a big warranty credit to put towards any tire of my choosing. I went with current tires.
You seem to be asking a lot of DRW questions. :B
โNov-24-2019 09:11 PM
โNov-24-2019 09:08 PM
Cummins12V98 wrote:
"One downside to the duallies is they eat front tires faster because big truck little tire."
I "PERSONALLY" have to disagree! As mentioned my 6 tires have the same tread depth all around of 1/4" at 30k. I have not touched the 4 rear tires except to air to 35 unloaded and 68 loaded since I am running over my RAWR a bit. I simply rotate the fronts side to side "keeping the rotation the same" and leaving wheels in their location. Think about that one!!!
BIGGIE is to have a proper alignment with toe set to 1/64". I run full 80psi fronts.
โNov-24-2019 06:18 PM
chevman
โNov-24-2019 06:08 PM
chevman
โNov-24-2019 10:57 AM
โNov-24-2019 08:15 AM
