Jul-15-2015 04:44 PM
Jul-23-2015 12:09 PM
Jul-23-2015 08:55 AM
Jul-23-2015 06:22 AM
GrandpaKip wrote:
A BAL scissor jack between the tires on the frame does the job for us. This is in addition to the 4 corner stabilizers.
Jul-23-2015 04:12 AM
GrandpaKip wrote:I was thinking the same thing, but would this still work if you didn't bolt it to the frame? The Harbor Freight jacks mentioned look like they could do the job well.
Jul-23-2015 03:40 AM
Jul-22-2015 11:16 PM
Jul-17-2015 07:51 AM
Jul-17-2015 06:52 AM
Jul-16-2015 07:32 PM
Mmwtdh wrote:
I find the less I extend the stabilizers the better they work. I either stack yellow blocks under them or I bought a set of light weight aluminum jack stands that I put under each foot....
Jul-16-2015 04:40 PM
Carrier wrote:tomman58 wrote:Carrier wrote:
Our 3008 Windjammer was terrible for bounce. Our 10 lb dog felt like a 300 pounder jumping in the trailer. Put x clocks on and it helped a little. Went to the local pick u part wreckers and picked up two of these for $10.00 both had never been used.
I would say 90% of the bounce is now gone.
Looks like you just set yours under the frame. I used tec screws and bolted them to the frame in the same manor as the Jayco folks. I had the electric stabilizers on my last 35' TT, I didn't care for them compared to the old scissor jacks.
Oh and I have an aluminum box on the rear bumper that holds 4X6X10" and 2X6X10" blocks to shorten the jacks stroke.
My latest is a 2015 Jayco 40' TT. I had them take my jack off my 35 footer and attach them for me .............. No charge but then that's Jayco here in Michigan
The more you RV the more you find what works and of course what doesn't!
Trailer is at a seasonal site for a couple more months. I'm making brackets and welding them to the top of each jack then clamp the to the crossbar that they are on now which is just in front of the front tires. It's a 2015 that will be going in for some warranty work this fall and I don't want to give any excuse to deny warranty with drilling any holes yet.
Jul-16-2015 03:47 PM
Jul-16-2015 07:08 AM
Muddydogs wrote:
I was noticing how much my trailer moved when chocked and the stabilizers tight while camping. I had made a chock like pictured but I used the Harbor Freight wood clamps instead of 4x4 blocks.
I only used the chock when unhooking at my house which is on a little hill just for added security but the last time I went camping I decided to chock the wheel with the wood clamp and WOW what a difference just having one set of tires chocked up tight made with the rocking. I plan on making another chock and doing both sets of tires next time out.
Jul-16-2015 06:45 AM
Jul-16-2015 06:12 AM
