Sep-24-2017 11:25 AM
Sep-26-2017 10:19 AM
jornvango wrote:My lift is mounted on my 11.5 foot 4000 lb Bigfoot TC. You would probably be using the same lift, which means it due to weight and size the lift would not work as hard with your TC.
We are considering having a stable-lift system installed on our 2014 Livin Lite 8.6 truck camper.
jornvango wrote:I seldom unload my TC when camping, but when I have I have never found uneven or unstable ground an issue. The lower hoop bridges the low spots, and on real low spots directly under a jack I have put leveling blocks. I have put leveling blocks under the hoop where the tires run over the hoop. It is certainly possible to find ground just too uneven to unload on, but you definitely do not need a graded level surface.
Since we love to boondock on public lands, we are looking for a solution that will allow us to easily remove the truck camper while we are camping on uneven/unstable ground.
jornvango wrote:I also have a lifted 19.5 foot Alpenlite 5th wheel. My Bigfoot TC with the Stable Lift will go more places and park in more places than the Alpenlite. There are more creature comforts in the Alpenlite.
The 4 wobbly jacks on our TC are too scary for us to use in these circumstances, but we do love to have the truck available for exploring while boondocking. We are currently considering trading in the TC for a travel trailer for this very reason.
jornvango wrote:That I can't comment on. I would suggest if you could swing it to have Stable Lift do the install or ask them if they could recommend someone. It is more time consuming than difficult. The most critical is the preload with the tie down feature.
Obviously, installing a stable-lift will be cheaper than the money we would lose on trading in the TC and buying a travel trailer.
jornvango wrote:I discussed that earlier.
Does anyone have the Stable-lift system and if yes, how is the performance on uneven ground?
jornvango wrote:My four jack systems have sank in the ground, but my lift never has. Four jack systems or Stable Lift, you can put pads under the jacks or jacks/hoop.
How about taking it off on forest land, desert ... does it sink in case of heavy rains?
jornvango wrote:As I previously stated, it is more time consuming than difficult. I installed mine with no help in two days. You have to remove some appliances to drill holes and install bolts. Each TC is different. I think I can post some photos if I still have them and you are interested.
Regarding potential negatives of the product: I'm aware of the difficulty to install (while reading up on the product); I would find a shop to install them.
jornvango wrote:If installed correctly, it will reduce the ground clearence about 2-1/2" to 3".
I'm also aware of the reduced ground clearance.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Sep-26-2017 09:53 AM
Sep-25-2017 09:23 PM
Sep-25-2017 09:22 PM
jimh425 wrote:
would work at different heights for each jack either. Better to lower the conventional jacks on blocks or stall mat squares.
jimh425 wrote:
I'm not saying it is typical, but sometimes the ground isn't very level even at campgrounds. In Yellowstone's Bridge Bay campground in one space, I had a different number of blocks under each tire to level the camper. I'm not sure how that would work with Stabile Lift, but it seems like it would either be unlevel or put a lot of twist in the system.
jimh425 wrote:
As far as fear of collapsing goes, anything can break.
Toad: 91 Zuke
Sep-25-2017 09:08 PM
SidecarFlip wrote:This is difficult for me to explain with the keyboard, but I will try. With independent jacks, three or four, each has clearance that is not tied to the other jacks. With the Stable Lift, typically three jacks and two guides, the clearence is connected to the three jacks and two guides through the connection to the TC and the lower hoop. The clearence is also stabilized with the use of the three struts from the hoop to the TC. I think this is where the idea of the Wobble Stopper came from.
I read the OP's post carefully. The OP was concerned with the 'wobbly jacks" on uneven ground. I don't see how a Stable Lift would help with that, especially if the ground is uneven or sloped.
SidecarFlip wrote:This is not an issue with the Stable Lift. I always left my TC at the height required to remove it from my truck. There were times I lowered it to make the steps more comfortable. The height of the lift is more stable than independent jacks even at maximum height, especially with the three struts.
You never want to use a TC with the jacks extended unless you like being seasick from the sway...
SidecarFlip wrote:I am comfortable responding to questions to help clear confusion or add to someones knowledge base. That is how I perceived your questions.
I'm not negative or positive, I just don't understand the OP's post, which is why I commented confused.
Toad: 91 Zuke
Sep-25-2017 04:01 PM
free radical wrote:
There are some reviews online if you Google stable lift,,explaining pro and con..
Only negative I see,
it leaves TC very high of the ground when off the truck which can make it being easily knocked over in strong winds,,??
Sep-25-2017 11:57 AM
Reddog1 wrote:
It is unfortunate, but it all probability the majority of the posts on this thread will be negative made by members who have never had a Stable Lift. Never having had a lift sure would bring up a lot of reasonable questions. Never having had a lift really does not put much validity in conclusions.
I have had a lift since 2005, and had to remove it last year due to changing to a DRW truck. I may offer some experiences with my lift later today, depending on how the thread goes.
Wayne
Sep-25-2017 11:49 AM
Sep-25-2017 11:23 AM
Toad: 91 Zuke
Sep-25-2017 10:18 AM
Sep-25-2017 08:38 AM
Sep-25-2017 08:04 AM
Sep-25-2017 07:45 AM
Toad: 91 Zuke
Sep-24-2017 07:35 PM
Sep-24-2017 05:31 PM
