Apr-17-2017 02:49 PM
Apr-19-2017 12:15 PM
Jim wrote:
I was referring to Flooded Wet Cells and did not reference them...
Apr-19-2017 12:07 PM
silversand wrote:BigFoot Ford wrote:
Your camper can not sit over 1-2 months without shore power on it or have solar to maintain your batteries.. Other wise you will be replacing batteries yearly.
.....kind of...My AGMs have been over-wintering in storage 7 months a year since I bought them in 2007 (10 years ago) with no maintenance whatsoever. I make sure that the AGM is fully charged just before storing the camper (the camper is stored indoors in a heated facility), then I snap the master battery disconnect to the OFF position for the duration of storage.
The AGMs are still in very, good condition to this day. Just picked the camper up yesterday from storage, and am running on the batteries after 7 months as I type (the camper is my office for the next 6 months, when then it will be in Florida), no problem. I'll charge them back to 100% this weekend 😛
AGMs are very, very, VERY slow self discharge over time (compare: flooded lead acid cells discharge much to quickly for my liking when sitting in storage)...
Apr-19-2017 11:48 AM
Apr-19-2017 07:13 AM
Apr-19-2017 07:09 AM
Apr-18-2017 10:03 PM
Z-Peller wrote:
As earlier poster said, check for battery disconnect switch. On your Bigfoot it is electronic disconnect switch surface mounted on a cupboard near the back door. If it is off then converter will not charge battery when plugged into shore power. If red light comes on when you are plugged into shore power but goes out when you unplug, then switch is not on. Red light stays lit up when switch is on.
Wow I feel like a dummy. I think mine was off. Just to be clear here, I want it in "Use" mode when I want to charge my batteries, right? And I want it in "store" mode when I want to disconnect my batteries?
Apr-18-2017 03:50 PM
Apr-18-2017 01:51 PM
RamblinAnne wrote:bigfootford wrote:
First, use absolute caution using jumper cables or even installing new batteries!
Even if someone helps you jump it... Watch like a HAWK! Know that + goes to + and - goes to -!!!!
Why?
There have been many disasters posted here on RV.net of folks hooking their batteries backwards and blowing all of the voltage sensitive appliances etc electronics... BIG $$$!
ABSOLUTE attention to polarity is necessary.
That said... There are many issues you will need to learn about.....A crawl before you walk thing.
If you could disclose an approximate where you live there should be some RV.net TC'er nearby that could help and teach you....
Do not go out and purchase batteries without first determining what type of Converter/charger you have.
The box that sits under the step is where the converter is on the BF.
Open the little door and check the make and model...
If it a Magnetek you will need to upgrade that. I am not sure what year they upgraded.
I can not even imagine AGM batteries being maintained by a magnetek so maybe the previous owner upgraded or the factory did.
Hope there is someone nearby that can help you get started!
Congratulations on your combo truck and camper... We love our BF... had it 17 years now... nearly 200,000 miles on it... hahahaaaa 2 trucks.
Jim
This is super helpful, Jim.. Thank you! I am on the very East End of Long Island, NY (The North Fork). I don't see many fellow campers out here so I doubt there are any around. But it's a big boating area and I have a marine electrician friend who is going to help me with my solar/battery setup when that time comes. I've just been focusing on the remodel right now and want to wait on the electrical side of things until I'm ready to start moving in.
I just checked and I have a Parallax 32amp Power Converter. Series 6300. I just googled and I guess this technically is a Magnetek? So it's no good huh? There's also this little Intellipower 9200 Remote Pendant thing that is hooked up to it. Not sure if that makes any difference to the overall setup.
So do I need to buy a new converter charger? Any recommendations? I'll be upgrading my battery bank to two 6V (haven't yet decided if I'm going with T105s or Lifeline AGMs.. but definitely two 6V).
Apr-18-2017 01:30 PM
Why?
Jim
Apr-18-2017 01:18 PM
Apr-18-2017 10:38 AM
Apr-18-2017 10:17 AM
Apr-18-2017 10:14 AM
Apr-18-2017 09:16 AM
