May-22-2017 09:21 AM
May-23-2017 08:08 AM
Old-Biscuit wrote:Rubber stems are only good to 65 PSI. Source. And, here is a link to a bulletin from the Rubber Manufacturer's Association, confirming that.
Steel valve stems not needed unless Tire PSI 100# PLUS
May-23-2017 06:55 AM
MarkTwain wrote:
X11, I always replace all rubber valve stems with stainless steel every time I buy new tires. Stainless steel stems will also minimize air leakage with traveling or when in storage.
May-22-2017 09:06 PM
May-22-2017 08:13 PM
May-22-2017 05:46 PM
Balance trailer tires.....IF it goes round and round at speed YES!!!
Upgrade from 'C' to 'D' again YES-----next year
Just keep tire pressures maintained/checked prior to travel days in AM COLD
Stay under 'speed rating' of tires Most likely 65 mph)
Stay under 'load rating' of tires (stamped on sidewalls)
May-22-2017 01:07 PM
May-22-2017 11:45 AM
rockhillmanor wrote:nephi007 wrote:
Hello. So we purchased a new Shasta Oasis 25rs in January 2016. The tires are 205 75 14 load range c. Constancy tires. (no doubt made in China) We drove it to Seattle and back to Salt Lake City approximately 2000 miles. No other trips. Tires performed well (i.e. they didn't blow up). No overloading. I have choices. (1) Tires ain't broke yet so don't fix (replace) 'em. (2) buy a TPMS system. If I keep tires at a minimum should I replace rubber stems with steel stems and have tires balanced? We are planning a return and back trip again to Northwest in July. Your thoughts please.
YUP X10!
First thing I did on the first RV I bought was to change out all rubber valve stems with stainless steel.
May-22-2017 10:50 AM
May-22-2017 10:33 AM
May-22-2017 10:21 AM
May-22-2017 10:02 AM
May-22-2017 10:01 AM
May-22-2017 09:56 AM
May-22-2017 09:55 AM
