โMay-26-2015 09:11 PM
โMay-27-2015 07:52 AM
โMay-26-2015 10:12 PM
dacraven wrote:
Old Biscuit you are the man.
pilot was aimed way off from the thermocouple, I gently re-positioned it and lit the pilot allowing it to heat up a little bit and switched it to on and BOOM, flows beautifully.
I have learned a little more each year in the maintenance and repair of my trailer as it's gotten a bit older and made some mistakes, but your advice has paid off for me, thank you for saving me the extra time and money. Much appreciated.
โMay-26-2015 10:03 PM
โMay-26-2015 09:55 PM
dacraven wrote:
My regulator or water heater has never been replaced, since we bought it in '05, it's an '02. Likely to be aged, but is only used a few times a year, which maybe could be part of the problem also I suppose.
I did NOT verify the position of the thermocouple over the flow of gas from the pilot however, that I will check, but would that also explain the pilot not staying lit as well?
I don't believe I have an ECO on my model as it has no electrical components. The unit is strictly manually lit and there is no reset. I have not replaced the anode as well, I have only discovered I needed to upon this issue arising.
Very helpful, thank you
Things that will shut off pilot when button released:
A weak thermocouple will drop pilot flame out------replace
A weak magnet in gas control valve will drop out pilot....replace gas control valve
A tripped ECO
The 3 things above will drop pilot flame when button released/turned to ON
And YES you have an ECO.
Like I explained it is the large probe that sticks out,,,....nevermind.
Dan C.
โMay-26-2015 09:51 PM
โMay-26-2015 09:38 PM
โMay-26-2015 09:37 PM
โMay-26-2015 09:36 PM
โMay-26-2015 09:31 PM
โMay-26-2015 09:18 PM
