Jan-14-2016 11:25 AM
Jan-15-2016 04:41 PM
Jan-15-2016 06:26 AM
Jan-15-2016 06:21 AM
~DJ~ wrote:Kayteg1 wrote:
I think the bands allow for truss movement.
I am researching the stinger hitch and I think for better strength it suppose to be welded, although it will make installation harder.
It may make it impossible. 🙂
Jan-15-2016 05:42 AM
Jan-15-2016 05:36 AM
Jan-15-2016 05:08 AM
Jan-14-2016 07:13 PM
AnEv942 wrote:
Hmm yes with one 'u-collar' I can see now how it could pivot/scissor closed. Ouch.
Maybe optical illusion, looks like the gap between the 2 tubes isn't uniform? Adding second clamp it wouldnt need to be so tight that tubes couldnt still pivot a bit if needed for insertion. But doesnt look like dealer error-, still think I'd add second clamp.
Im noting the use of the quick links..were those dealer installed? Ive never had luck with them long term-threads gall if high load seen (or me reefing on em).
..edit- with the tubes removed from hitch and the single bolt clamp at opposit end, theres nothing other than friction to keep the ends from closing, unless your finger(s) is between the tubes.
Jan-14-2016 07:02 PM
Jan-14-2016 07:01 PM
Reddog1 wrote:
With my experience in welding/fabrication, I still cannot see the pinch points. Something has to be flexed/under tension.
Jan-14-2016 06:54 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Jan-14-2016 06:40 PM
Bedlam wrote:
There are two trusses coming out of the two receivers. If you only have one collar the trusses will not stay separated and will fall on each other when removed. With two collars, the separation is held and will not pinch your hand. Sorry, no pictures to illustrate this.
Jan-14-2016 06:38 PM
Jan-14-2016 06:27 PM
Toad: 91 Zuke
