โJul-28-2014 01:43 PM
โAug-02-2014 09:45 PM
โAug-02-2014 08:47 PM
โAug-02-2014 06:52 PM
โJul-30-2014 12:23 PM
This is why I am skeptical that a 1/2 ton or smaller truck really can safely carry any truck camper at all by the time it's loaded to go out for a trip.
โJul-30-2014 10:28 AM
ah64id wrote:
While I am not a fan of big payloads on 1/2 tons my buddies 05 non-HD crew/SWB F-150 has a sticker payload over 3K. That's with OEM 6 lug wheels , 3850? RAWR and a 7200 GVWR
They do exist, I still don't think it's the best way to do it and neither does he. On paper he has more payload than I do, in reality they aren't comparable.
โJul-30-2014 09:09 AM
โJul-30-2014 08:00 AM
โJul-30-2014 07:57 AM
โJul-30-2014 07:25 AM
ZRX-Steve wrote:
I found this regarding the HD Payload package too:
F150 HD Package
- high capacity wheels
- LT tires
- HD shocks
- upgraded rear axle: 9.75" gear set (instead of 8.80")
- upgraded springs
- upgraded radiator and aux. transmission oil cooler
- stronger frame on all but screw (0.150 instead of 0.110 rail thickness). Screw has 0.150 rail thickness regardless of HD payload package already.
โJul-30-2014 06:46 AM
mkirsch wrote:
What 1/2 ton truck, save for the "fake" 1/2 tons, is going to be able to comfortably haul a camper like this? You're looking at 2500+ by the time all is said and done, 1000+ over your real available payload capacity.
โJul-29-2014 05:42 PM
โJul-29-2014 05:27 PM
โJul-29-2014 01:36 PM
โJul-29-2014 01:30 PM
Bedlam wrote:
Your F150 most likely has the semi-floating Visteon Ford 8.8 axle. Since the shafts are supported only on one side with bearings, it only has a 3800 lb rating for the 6-lug version. The semi-floating 9.75 axle with 7-lugs has a 4800 lbs rating. If you can keep less than much weight off the axle, you will be fine.
