Apr-27-2020 08:34 PM
Apr-30-2020 09:54 PM
Apr-29-2020 07:35 PM
Oldskoolsteve wrote:
I investigated and it appears the 12 volt+ turns off when the key is off.
So when the key is off in the truck, the camper would only be powered by the camper battery. And the circuit for the truck is completely open and no feedback or draw can happen to the truck. Correct?
Apr-29-2020 01:06 PM
Apr-29-2020 12:23 PM
Apr-27-2020 10:52 PM
Apr-27-2020 10:17 PM
Does the power (+) from the 7 way (the truck) plumb directly to the battery and trickle charge when the truck is running? I don't think its more complex than that? Usually trucks have 30 amp charging wire, so that is more than a trickle. Some campers have built-in battery separators with fuse
The power (+) from the truck 7 way then disconnects upon turn off leaving the camper system independent, correct? From what I read, only Ford does that. Other brands have no power disconnect
Add in my 3 way fridge. Where would the 12v (+) & (-) hp in the 7 way cable?
It goes from camper battery. All you have to do is push the button on control panel
Forgive the ignorance, it seems very simple...but I don't want to screw it up!
Thanks in advance
