TC Camper Sealant Questions
explorer0863
I am going to seal my entire TC this fall and I have several questions.
I understand that I need the following products. Could you guys confirm or recommend the right product and quantities?
> Geocel ProFlex RV – white. 3 tubes sufficient?
> Geocel ProFlex RV – clear. 3 tubes sufficient?
> Dicor self-leveling lap sealant – white for the roof. What quantity do I need?
> I can’t find Geocel MHRV 2300 anywhere online. Was this product discontinued? Did Geocel ProFlex RV replace it?
> I am not clear on what is a TPO roof, but I don’t think I have that type. I believe that I have aluminum roof. Those of you familiar with my model, am I right? Or, how can I verify it?
> I am planning to wax it and remove oxidation as well. Should I do this before or after sealing it?
Many thanks for your help!
Tony
2014 Silverado 3500 Duramax/Allison
2015 Lance 1172
Previous:
2004 Dodge Ram 3500 DRW Cummins
2004 Lance 1161
19 REPLIES 19
skipbee
We have been switched to Liquid Roof instead of Dicor on the roof seams, by our Lance Dealer. It has been very effective, easier to apply with a brush, and not as expensive. Follow the directions, of course, and be sure to stir the two parts with a stirrer affixed to a portable drill. We froze the remaining stuff, it worked fine after thawing.
skipbee
2004 F350 Diesel CC SRW 19.5" Rickson W/T 4WD
2005 Lance 1121 well found.
See us on YouTube" Living the Lance Life" 3 of 4. Google skip bosley for TR's: Alaska, Assateague Island, Disney World & Fla Keys and a California Coastal jaunt.
Peg_Leg
If it's alum, just wash it with TSP (Tri Sodium Phosphate). Rinse with plenty of water all the way down the sides. Right after the top we always washed the sides with a Turtle Wax Wash. After it's dry go up and remove any cracked caulking with a plastic scraper. Then just use the self leveling sealant around every opening through the alum, vents, skylights, AC etc.
I had a TT with alum roof, loved it. After 18 yrs still looked new except for some hail indentations. We never had any black streaks using the TSP. Just make sure to rinse the sides or it will fade the paint. I used a cup of TSP powder in about 3 to 4 gal of water.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Desertboy
dave17352 wrote:
I just went through mine. Did most of the roof with eternabond tape. I used some dicor self leveling also on the roof. The eternabond seems great but I will be interested in seeing how well it stays stuck in place. The dicor seemed to work very well also. I used sikaflex for everything else. I cleaned where I was caulking with mineral spirits then cleaned off with water before re caulking. Remember don't use any silicon anywhere on the outside of your camper.
whats wrong with silicon? I haven't used any im just curious what it does or what happens to it.
1969 AVION
3/4 12 VALVE
Freightliner/24' Flatbed 50,000 miles/ Titan 4000 receiver Hitch, no Mods needed.
bobndot
Proflex RV in 'brite white' if you can find it. 'White' tends to yellow.
dave17352
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
