They make a load range D now
solismaris
I'm going to need some new tires, ST205/75R15.
8 years ago I bought the Goodyear Marathon, in a load range C. Actually all the trailer tire brands of that size were load range C at that time.
Now I see they make a load range D of the same size. I didn't know that was possible. 65 PSI instead of 50. For example,
the "Goodyear Endurance" listed on Town Faire Tire.
So 2 questions:
Any concerns changing from lr C to D? From the numbers I assume I can reuse my old rims and everything will fit; just add 15 extra psi.
and,
What's the general opinion of the Goodyear Endurance in general? I really have no complaints about my old Marathons but at 8 years it is more than time to replace (and one of them just died from road damage anyway!)
David Kojen
9 REPLIES 9
time2roll
solismaris wrote:
So 2 questions:
and,
1: Switched to LRD 6 years ago. Maxxis had tread separating so the Endurance went on about two years ago. No issues running 65 psi. Rides better than ever.
2: Excellent tire so far.
profdant139
I've got Endurance in range D -- 14 inch -- on a 2500 pound trailer, with a 12 foot box. Like a toddler wearing Daddy's hiking boots! ๐Ÿ˜‰
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Tom_Barb
I have always up graded to range D light truck tires on all our equipment trailers, We load to 14K and never had a problem in 15 years.
Vintage465
On our Creek Side 20fq it came with 205 C-rated Marathons. I replaced them at 20,000 ish miles 225 E-rated Endurance Goodyears for piece of mind. My rims on the axles were wide enough to accept the larger tire. I had to replace the rim for the spare as it was a narrower steel rim. It's a good feeling riding on E-rated Goodyears made in USA.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
myredracer
When we bought our 2014 TT new, standard tire size was LRC ST205/75R15 in a generic Chinese brand. LRD Marathons were available as an option so we got those and the section width went to 225. IMO, wider is good. Max. sidewall pressure in the LRD Marathons is 65 psi and that's what I've used from day one on our 7K lb TT.
Even with the higher load range, inflate them to the sidewall max. You'll have a higher reserve load capacity that way which is a good thing and will reduce the risk of a blowout. It's probably a good idea to check the psi rating on the rims. Can always run the new tires at a lower psi *if* you had to per load inflation tables.
If you ran on the Marathons for 8 years, most people replace any brand of ST tire at around 5 years old.
We're about to install new Endurance in the same width but they now become LRE. Our rims are good for 80 psi max, so that's what I going to inflate them to.
Huntindog
So 2 questions:
and,
Hmmm. I had Marathons in C, D, and finally Es before I gave up on ST tires in 2006. I will say that I remember having to order the Es.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
RobWNY
Goodyear Endurance gets a ton of positive reviews on here and other sites. Jayco is putting them on their campers as standard tires now. My buddy has a small Jayco camper that came with Load Range D Goodyear Endurance tires. I just swapped out my Castle Rock China Bomb tires with Load Range E Goodyear Endurance Tires. Maxxi's and Carlisle tires also get good reviews.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
ktmrfs
if your rims are a stamped steel rim, they should have a max pressure stamped on the rim. More than likely they will handle LRD
On the endurance, I have about 10K miles on a set I got a little over a year ago. So far I have been impressed. the balanced easily ( a sign of decent mfg) they are a speed rated tire (87mph IIRC) and so far those using them have had a good experience in general.
And when I got mine they were the same price as Maxxis, which I had run before with good luck.
2011 Keystone Outback 295RE
Lwiddis
Iโ€™ve run 14 inch Load Range Ds for a while now. 15s are also available. Not new. If your rims are rated for at least 65 pounds youโ€™re good. 15 inch Load Range Es are also available.
https://www.etrailer.com/dept-pg-Tires_and_Wheels-sf-Tire_with_Wheel-tw-Load_Range_E-pc-15_Inch.aspx
