Insulation thickness for a given R value will vary depending on the quality of the product, so it's tough to get the right answer unless you tear a wall apart to have a look. I'm sure you don't want to do that.
If you can physically measure the wall thickness, that would be the way to go IMO.
Really though,
IF the studs are made from 20 gauge aluminum (maybe 1/16" thick), the wall covering over the stud is ยผ" thick, your mounting bracket is ยผ" thick, and you want say ยฝ" penetration in the stud, then you could go with a 1 ยผ" or 1 ยฝ" stainless self tapping screw. Remember that the tapping end of the screw is maybe ?" to ยผ" long and is not threaded, so has no holding power.
Sounds to me like 1 ยผ" would work fine. Fill in the blanks with your variables if you want, but I suggest you get a wall thickness first and go from there. Hope this helps.
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
