โJun-23-2015 07:46 AM
โJun-23-2015 07:06 PM
โJun-23-2015 06:17 PM
โJun-23-2015 05:14 PM
jefe 4x4 wrote:
The battery is at 12.6 volts now and it's clear that the 2amp charger had no juice and the charge was slowly going down due to the parasitic drag from safety appliances.. So, the question is: shouldn't the 12v circuits work with 12.6 v.even when not being plugged into the 30amp 110vAC?.....
โJun-23-2015 12:36 PM
jefe 4x4 wrote:
O.K., the plot thickens. After reading all your responses, I checked all the 110v breakers in line with my circuits, I used my non-contact voltage tester and worked my way back from the TC to the GFCI plug. No circuit. Tried to reset the reset button and it won't stay in. So, I hooked up another 80 feet of extension cord and ran it to our attached garage. This should work, right? Wrong. THAT GFCI was also non-responsive. Two in a row? I found a closer plug inside my train room and tested that plug. Works fine. Ran 50' of cord out the 12' rollup to the camper and plugged in the 30amp cord. Bingo! The soft, telltale hum of my old Magnatec was detected. I then worked my way thru the Box testing every single circuit. All work fine and my 110v night light was glowing nicely. All the new upscale bulbs were good.
Thanks ever so much for your kind attention. There is not an RV forum on the planet that has as much knowledge as youse guys possess.
I think Lawrence Welk, the king of malaprops, talking to his band summed up the day as well as anyone:
"My poys, der are good days and der are bad days, and dis is one of dem."
โJun-23-2015 12:23 PM
โJun-23-2015 11:00 AM
โJun-23-2015 10:38 AM
โJun-23-2015 10:28 AM
โJun-23-2015 09:45 AM
โJun-23-2015 08:29 AM
โJun-23-2015 08:14 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โJun-23-2015 08:13 AM
โJun-23-2015 08:04 AM
โJun-23-2015 07:50 AM
