โDec-20-2018 07:13 AM
โDec-23-2018 07:06 AM
jaycocreek wrote:
But that's old school..Won't work now with the internet and all! :B
โDec-23-2018 06:05 AM
TxGearhead wrote:
I used stake pocket tie downs on an 8ft cabover back in the 1980's with no issues. I don't have a clue how much it weighed. Wood framed all aluminum siding and roof, stove, sink, porta-potti, roof A/C. The tie downs had a 3/8" bolt and washer that secured them in the pocket. Turnbuckles with springs and wing nuts. I did a bit of off road driving and never noticed much camper movement.
Just me, but I would do that on all four corners.
โDec-23-2018 05:10 AM
โDec-20-2018 04:16 PM
โDec-20-2018 03:18 PM
โDec-20-2018 11:47 AM
โDec-20-2018 10:56 AM
SidecarFlip wrote:
Don't forget to say you used schedule 60 square tubing...
โDec-20-2018 10:54 AM
work2much wrote:
I had the brophy pocket style tie downs on my first camper and quickly moved to a happijac down as I didn't find them very sturdy bending themselves and somewhat mangling the truck. That was over 20 years ago. Maybe they work better now. I switched to happijac bed mounts and didn't like them either as they tore the sheetmetal on our 1994 Ram. I know others here have had better success and I'm sure the product has improved over the years. After the happijac we went with a frame mount that has worked well on the last 3 trucks and 4 campers. I believe you can buy just the fronts if you are doing your own thing on the rear. Some sort of spring is recommended by most camper manufacturers to relieve stress on the camper.
โDec-20-2018 10:51 AM
Kayteg1 wrote:
I build rear tie-downs myself as I could not justify spending $300 for Torklift model.
All it took was 1" square tubing, some pieces of old receiver as my truck has 3" hitch and top it with 3" framing square washer from Home Depot.
I slid the adapter into end of hitch cross tube and secured with 1/4" pins.
โDec-20-2018 10:49 AM
ajriding wrote:
This guy did what Im thinking of. I will be towing a cargo trailer on that same extension too.
https://lookbeforeyoulive.com/?p=22714
I have also seen on etrailer there is a clip that can be bolted into the rear bumper. How do these work? My bumper seems pretty sturdy.
If I knew the forces involved it would be much easier
โDec-20-2018 10:36 AM
โDec-20-2018 10:32 AM
โDec-20-2018 10:21 AM
โDec-20-2018 10:12 AM
