Tire covers
1Longbow
Just wondering if you like the the single type tire cover or the double size covers better.Is there a brand that is better than the rest? Are they pretty true to size ? I need a set that will cover 225-75R -15's and want to make sure they will cover the whole tire and rim . Thank you for your replies
7 REPLIES 7
brirene
I've had a double set of Adco's for 7 years, use them all year. Just starting to crack so will need to replace before winter. Think I got them bogo at CW.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
FLGup
I prefer the double tire cover as it covers my RotoChocks too. This hides them from thieves and keeps the sun off them as well. I had the white covers but the soon looked ugly from dirt and grass stains. When they wore out (cracked and brittle from the sun) my second set is a black set and they are great so far. I haven't had the black set long enough to comment on the sun exposure yet.
One extra note......if you go with a double tire cover, the slide out may have an adjustment bolt that sticks down low enough that it can hang on the tire cover in the middle. I had that problem. I solved it with a bungie cord around the tire cover middle on the slide side.
FL-Guppie "small fish in a big pond"
2024 Grand Design 22MLE
2018 Ford F150 SuperCrew 3.5L Ecoboost, maxtow
Dakota98
gbopp wrote:
Harbor Freight Tire Covers
It's a good deal but, it's only for up to 24" diameter tires.
Although that's the specs given, my tires are 24.5" diameter, the covers will fit a larger size with ease.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
gbopp
Dakota98
tralertrash wrote:
http://www.harborfreight.com/catalogsearch/result?q=tire+cover
set of 4 -$10 works just fine
X-2
I'm om my third season using these from HF.
Also, if you want to protect a little more, use this stuff.
RAY-BLOCK
2006 POLARIS ATV
USMC 68-74
tralertrash
chateausport
As long as you cover the outside wheel from the sun your set.
