โMay-03-2018 12:59 PM
โMay-03-2018 08:13 PM
โMay-03-2018 07:41 PM
โMay-03-2018 03:16 PM
MFL wrote:
Yes, radial tires are better than bias for your TT. You do need to run the same, either all radial, or all bias. Yes, fill the tires to max pressure, when cold, not after traveling. Check the low tire often. If only one is low, there is likely a reason. A low tire heats up quickly, and will blow out at some point.
Jerry
โMay-03-2018 03:04 PM
โMay-03-2018 02:30 PM
โMay-03-2018 01:08 PM
bob213 wrote:
The D means its a bias ply tire not a radial. You are much better off with the radial. Both type trailer tires should be inflated to max pressure.
โMay-03-2018 01:05 PM
