โAug-03-2015 06:12 PM
โAug-06-2015 09:24 AM
Atlee wrote:
And why did you bust beemerphile1's chops.beemerphile1 wrote:
I would think a senior member of these forums would know.....
โAug-06-2015 03:11 AM
Vulcan Rider wrote:beemerphile1 wrote:
ST (special trailer) most common tires on trailers
MH (motor home) does not use trailer tires and they are expected to last longer
And you would be wrong.
So what is "special" about trailer tires ?
And what difference is there with a "motor home" tire ??
When I got mine replaced, I went to a truck tire dealer and got (I assume) truck tires (LT) of the proper size and load range.
I suppose someone will tell me that was the wrong thing to do.
โAug-05-2015 05:56 PM
โAug-05-2015 03:34 PM
Huntindog wrote:
But the ST fans will try to scare you by saying that you must use the exact tire that is on the placard.
โAug-05-2015 12:18 PM
Vulcan Rider wrote:Yeah, there will be some that tell you that. IMO, and many others, using LT tires when possible is a very good upgrade. So good that quite a few high end TTs either come stock with them, or offer it as an upgrade.beemerphile1 wrote:
โAug-05-2015 11:19 AM
โAug-04-2015 05:59 PM
โAug-04-2015 05:58 PM
โAug-04-2015 05:28 PM
โAug-04-2015 04:51 PM
Industry recommendation is seven years for ST tires and ten years for MH tires.
Too many abbreviations.
Please explain ST and MH.
And why there would be a difference.
Different rubber compounds; different construction ??
โAug-04-2015 11:08 AM
โAug-04-2015 10:43 AM
โAug-04-2015 10:30 AM
โAug-04-2015 09:29 AM
abc40kids wrote:
I'd go with 5 to 6 years covered or not. If u keep the air up and speeds down and only short trips might get another year out of them.
