tongue jacks
jamiet
iv got a 29ft tt weight 6700 is a 3500bl bulldog electric jack a good size and choice
4 REPLIES 4
Taplep
Good choice. I bought my Bulldog 3 years ago and I am very happy with it.
2010 KZ Sportsman S272BH
2010 Toyota Tundra Double Cab
fla-gypsy
Good choice
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
hddecker
You need to check the size of the shaft, will it fit hole in the A frame.
There are 2 different sizes of shafts for travel trailers. I found that out the hard way, I managed to destroy my tongue jack, a quick trip into town buy a new one, when I install it I find that the shaft is smaller than the hole in the A frame. This resulted in wobbly lift, to get the trailer hooked up for the trip home. Once we got home I had to find a sleeve to go over the shaft of the jack, to fill if the gap.
However as Samson says good choice, if it fits.
samsontdog
It is a good choice and size as you might go with a bigger TT then you can keep the 3500 and install it on the bigger TT
samsontdog:o:W
