โJul-06-2020 07:07 PM
โJul-07-2020 07:05 AM
โJul-07-2020 06:59 AM
โJul-07-2020 06:52 AM
โJul-07-2020 06:39 AM
APT wrote:
I would plan for about 4000 pounds dry. That gets you in the 4500-5000 pound range. The 3.3 will spend a lot of time in the 3000-4500rpm range due to combination of weight, wind resistance, and engine torque. If that is acceptable for you, then go for it.
BTW, what hitch weighs 100 pounds? Shipping weight for my Reese Strait Line is 70 pounds and not all of that is dead weight on the TV.
Jebby14 wrote:
possible yes, comfortable likely no. another option to consider is daytripping or tent camping to find your prefered location then buying a park model there. will give you way more bang for your buck. Bettter yet you can grab an older pop up for exploring quite cheap and usually get most of your money back selling them unlike travel trailers.
โJul-07-2020 06:32 AM
โJul-07-2020 06:20 AM
Jebby14 wrote:
A trailer needs enough tongue weight to pull correctly. too little causes sway. the sweet spot on travel trailers us usually 13-15%.
the truck has to be able to carry that weight which is why on suv's and half ton trucks payload is typically the limiting factor
I would recommend you re-evaluate what you want. if its going to be seasonal buy a seasonal. if its travel either get used to a smaller camper or get more truck. if you opt for a smaller trailer understand you will likely be going larger (and still needing more truck) later.
โJul-07-2020 06:16 AM
โJul-07-2020 06:00 AM
โJul-07-2020 05:48 AM
โJul-07-2020 05:35 AM
โJul-07-2020 04:55 AM
Jebby14 wrote:
1640
-100 for the hitch
-500 for the family (guessing modify this to your needs)
-300 for randoms (food, coolers, gas cans, gear whatever again modify since im guessing)
=740 left for payload
740 / 0.15 =4933 fully loaded.
assuming my numbers are correct your rig shouldnt weigh more than 5k fully laoded to be able to carry 15 percent of the trailer weight on the tongue for a nice tow. dont look at dry weight look at GVWR. id guess you will be around 24 feet.
โJul-07-2020 04:50 AM
ken56 wrote:
Your first trailer will not be your last. You say you want to park it a destination campground in the future but how far out in the future? Are you going to pull it to places while the kids are young like the Grand Canyon and Yellowstone and Mt. Rushmore, you know , long trips cross country?
You will find that by taking longer trips and really using your trailer if it suits your lifestyle to the point of parking it for long term use. Floorplan is critical to function and how YOU use it. we started RVing in 2012 and are on our 3rd trailer. We like this one, finally.
Your truck will handle towing a trailer in the 5000lb empty range but the payload number is the one to watch as others said. I pulled a 6500lb trailer with my Chevy 1500 just fine.....most of the time. I did tow an 8000lb trailer for a friend and it was a struggle with my 1500. Get the best hitch you can afford. Equal-I-Zer is a good one for fair money. Make sure you size it for the heaviest tongue weight possible for your combo. A 1000/10,000 should do it for you but you might consider a 1200/12,000 if the tongue weight is anywhere near 1000lbs.
โJul-07-2020 04:09 AM
โJul-07-2020 03:55 AM
