Confusing using marketing nomenclatureโฆF150 has over a dozen different onesโฆso which one ?
Best to use their actual ratings. Like GVWR, FGAWR, RGAWR.
Look at the RGAWR and get the one with the largest rating. There is a reason why the bigger TVโs will have RGAWRโs starting at 6,000 lbs.
IdaD mentioned the F150HD and that one will have the highest RGAWR
As for the trailerโs tongue weight vs your possible TV purchaseโฆlook up itโs advertised weight and tongue rating. That is normally an empty trailer and will provide for guesstimating of the actual tongue weight
What you are looking for is the tongue percentage weight.
Then take the trailers GVWR to figure out itโs tongue weight to figure out if that TV will be rated for that
Not a sure fire, as depending on the trailer, some will have their loaded tongue weight something other than the brochure tongue percentage.
If you are stuck on purchasing this TV and trailer, then take the trailer brochure listed weight & tongue, which is an empty trailer with no optional equipment like propane tanks, spare, battery, etc.
Then subtract that from the TVโs GCWR and that is the maximum your TV can weigh and still meet GCWR.
I have no skin in your game and am just providing information for the OP to make a good decision.
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
