Mar-11-2021 11:05 AM
Mar-13-2021 06:49 AM
Mar-12-2021 08:02 AM
Mar-12-2021 07:37 AM
afidel wrote:
Sure, you're well inside all manufacturers specifications. Only you will be able to decide if the screaming 2.7 is something you can put up with long term. Plenty of diesel folks say they can't stand a V8 at 3k RPM due to noise, I hardly notice it, you might be the same with the 2.7 😃
Mar-12-2021 05:24 AM
Mar-11-2021 06:13 PM
philh wrote:
what is the payload capacity of your truck?
Mar-11-2021 05:57 PM
Mar-11-2021 05:12 PM
Mar-11-2021 04:14 PM
Mar-11-2021 03:53 PM
afidel wrote:
You need to verify your equipment package, if it's 53B then you're limited to 5,000 pounds as you don't have the stronger receiver or the AUX cooler. 53A which would give the higher tow rating should include a controller.
*edit*
Hmm, actually looks like only 53C (Max tow) included the brake controller. I would still verify the package.
Mar-11-2021 02:49 PM
