Tranny fluid change
azdryheat
Got 70,000 miles on the current ATF oil, so today it and the spin-on filter got changed. I also dropped the pan to see if there was any sludge and it was clean. Love this Duramax/Allison combo.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
60 REPLIES 60
Cummins12V98
"I also use used oil in the gasket, can always remove by hand and not a leak yet."
The "YET" part is what scares me. If the filter says tighten a certain amount after contact I do so. Honestly if a filter can be removed by hand after 5-15,000 miles that is loose IMHO.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
azdryheat wrote:
The Allison does come with a drain plug. I was just curious to see what was in the pan. Oh, and Allison does not recommend a fluid flush or exchange.
Show me where they say NOT to do an exchange. Big difference between that and a mechanical flush.
Cummins12V98
Geo*Boy Said
"Yes you can. Fill the transmission up, according to the dipstick, remove the return line from the oil cooler, install hose fitting, start truck, pump out a gallon, refill repeat until nice clean fluid appears."
BINGO......We have a winner!!!!!!!
To make it easier check fluid level before starting job. Measure amount removed from pan and replace the same volume then do the start run and refill exactly what has been pumped out.
rhagfo
RAS43 wrote:
RambleOnNW wrote:
Iโ€™ve got the Ford TorqShift with the external bypass filter in a housing and itโ€™s quite frozen. Couldnโ€™t crack it loose with a 1/2โ€ rachet and didnโ€™t want to break something. Thinking about trying to use a filter wrench on the filter housing along with the rachet on the end nut. Any tips?
I haven't had that issue but I'd try using a 1/2" impact gun turned down a bit.
Great suggestion, I have seen an impact wrench break loos a nut and using a breaker bar, would have snapped off.
When you do get it off don't over tighten the new one!
When I replace my oil filter on my Cummins, I only tighten the 3/4 turn after the gasket makes contact. I also use used oil in the gasket, can always remove by hand and not a leak yet.
RAS43
RambleOnNW
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
ktmrfs
Seon wrote:
Cummins12V98 wrote:
What about all the "OLD" ATF left in the converter???
You'll never get all the oil out, even by a professional shop
Next time someone drops their oil pan, best to install an oil pan drain plug. Much easier for the next oil change.
allison already has a drain plug. no need to add one.
2011 Keystone Outback 295RE
rhagfo
Did this on both of my old Ford C6 transmissions. What I did was start and start adding as it drained the keep up as helper went through the gears slowly.
azdryheat
2019 RZR 1000XP TRE
FishOnOne
Pretty much what I found when I did my ATF along with a small amount of fine particles on the oil plan magnet.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Geo_Boy
Cummins12V98
Too funny, the only vehicle I have not done a complete fluid exchange on is my current AISIN. It does have a factory pan drain plug as I would assume the Allison does.
Seon
Cummins12V98
azdryheat
ktmrfs wrote:
no real reason to drop the pan. Only time the pan needs to be dropped is if there is some reason to do internal transmission work. That's what's nice about the spin on filter.
I went to the deep pan on both my trucks, rather than the shallow pan the truck comes with. So the pan did come down for that. Being overly anal mostly.
BTW, on both my duramax trucks, I did a drain and fill with allison transynd rather than the GM fluid. Lasts longer, holds up better, and NAPA sells it at reasonable prices.
I dropped the pan to get all the oil out (about 1/2 quart was still in there) and to check for sludge (102,000 miles on the ODO).
I checked on the 295 oil and but went with Valvoline VI since it's done a great job so far and I didn't want to drive across town to NAPA.
2019 RZR 1000XP TRE
