Jul-04-2017 01:28 PM
Jul-04-2017 09:45 PM
looper wrote:
This sounds exactly what's happening with mine. It's most obvious when backing into my driveway which is a slight uphill. It has only "blown" fluid once that I am aware of because there was fluid on the front of my TT. I use the recommended Mercon fluid and
Jul-04-2017 05:38 PM
Jul-04-2017 03:48 PM
lenr wrote:
My son has a 2002 F-350 dually 7.3 diesel. His transmission only leaks when he backs the trailer up a hill after towing home on a hot day--I believe it is the rear seal. That is the famous Ford 4R100 transmission which is not famous for reliability, as opposed to the 7.3 engine. Other son lost his at 100,000 mi. First son decided that it was cheaper to fill the fluid occasionally than pay for a complete rebuild before it goes out completely--has been running this way for over 50,000 mi. Most Ford transmissions are not hurt by overfilling--they just blow it out the breather--still best to properly fill. As said above, need to find out where the fluid is coming out. Best advice would come from an independent, non-chain, transmission shop.
Jul-04-2017 03:27 PM
Jul-04-2017 03:20 PM
Jul-04-2017 02:24 PM
Jul-04-2017 01:44 PM
Jul-04-2017 01:35 PM
Jul-04-2017 01:31 PM
