Aug-24-2014 06:40 AM
Aug-26-2014 04:31 PM
Aug-26-2014 03:08 PM
Tystevens wrote:intheburbs wrote:
And lastly, the Excursion has a GVWR of 9200 lbs. Yet it only has a payload of 1350? Its curb weight is 7850? Seems a bit high to me....
If it is a diesel, it certainly could weigh 7800#. That PSD is a heavy drivetrain inside an already heavy truck.
Aug-26-2014 03:03 PM
intheburbs wrote:
Well, based on my data point of "one," I can say that as soon as I exceeded the door sticker numbers, stuff started to break.
My half-ton Burb is on rear end number 4. I upgraded my trailer in 2010, thinking the half-ton could handle it.
1) 2010 - Spun the pinion bearing while vacationing. Spent 3 days in Youngstown, OH.
2) 2011 - Seized the rear end while vacationing. Spent 4 days in Mitchell, SD.
3) 2012 - rear end replaced under warranty, likely because of improper break-in.
2013 - bought the 2500 Burb.
2014 - beat the snot out of the 2500 on a 5300-mile vacation out West, including four wheeling and the Eisenhower Tunnel, and nothing broke.
Folks can do whatever the heck they want. I'm simply sharing my experience with an almost-identical vehicle. 10-bolt semi-floater rears don't like excess weight and high temperatures.
Aug-26-2014 02:03 PM
intheburbs wrote:Well not a Burb but had the same thing happen to my Dodge 1500 and I was under weight. I replaced the rear end gears, transmission, front ball joints all before it had 80K miles.
Aug-26-2014 10:25 AM
Aug-26-2014 09:30 AM
Aug-26-2014 09:13 AM
majorgator wrote:Those numbers like payload which is based on GVWR are NOT RECOMMENDATIONS. They are SAFETY CERTIFIED NUMBERS verified by extensive safety related independently performed tests in accordance with a set of uniform testing protocols
Well, that's not entirely accurate either. There is no "uniform testing protocols". There's extensive online articles about how the manufacturers have never been able to agree to a uniform set of testing and rating protocols when it comes to determining what their product's capacity and capabilities are. Every time they've tried to agree, someone breaks rank and then no one participates. Supposedly, they've reached an agreement beginning in 2015 to a set of uniform standards, but there are no government mandates to do it. There are no "independent performed tests" which have a bearing on the door sticker, and all tests are done to the bias of the manufacturer. Some folks have come along and performed independent tests, but those are "informational only" and will never be published my the manufacturer. This has been a huge complaint since the 1990's.
Bottom line is that the ratings on the door sticker show what the vehicle ratings are in its "stock" configuration...right off the assembly line. Aftermarket mods can have a positive or negative effect. It is absolutely common for people to exceed the ratings after they've done some level of mods to their TV. I'm not saying its right or wrong, and one should never perform mods without very diligent research. Its the people that exceed ratings blindly that should scare you. If your TV is under warranty, that would obviously be a big NO-NO.
Aug-26-2014 08:34 AM
Aug-26-2014 07:31 AM
He will be fine as long as nothing goes wrong again.
He got a huge ticket for not having enough truck for the trailer, no sway control, no brakes and no tow mirrors.
Aug-26-2014 06:57 AM
Aug-26-2014 06:29 AM
Aug-26-2014 06:19 AM
Aug-26-2014 03:35 AM
rbpru wrote:
The bottom line to all this is you can pull most any TT with most any TV.
The sticker on the door post tells you how much your max cargo can be, it is up to you to decide how heavy you wish to load the vehicle.
Usually, even with a WD hitch leveling out the load, your TT and stuff will probably exceed the vehicle’s max cargo limit before you are exceeding the vehicle’s towing limit.
Contrary to some opinions, this is not a crime against humanity, it is simple the decision to exceed the manufactures recommended limits.
As for power and gas mileage only you can be the judge of that also. I once towed a 6000 lb. trailer with a 200 hp. Ford F-150. It topped out at 52 mph on any hill. It did not ruin my vacation but it did make for slow going. I also made for an Eco-Boost TV shortly thereafter.:)
Aug-25-2014 06:10 PM
