โMar-22-2014 08:10 AM
โApr-20-2014 01:49 PM
โApr-20-2014 12:53 PM
mayo30 wrote:
I just use a spare 12 volt rv Shur flow pump and garden hose to pump it in from what ever water container I use.My battery leads are short,as I set the pump by the battery case.I can usually fill and empty the jugs in the truck without lifting in and out,by getting close enough to fill taps and Rv.
โApr-20-2014 10:10 AM
โApr-20-2014 09:18 AM
โApr-20-2014 05:34 AM
โApr-08-2014 08:26 AM
โApr-08-2014 06:36 AM
โApr-03-2014 05:05 PM
โMar-22-2014 05:16 PM
NanciL wrote:popeyemth wrote:
Add a 6 inch piece of hose to the funnel to get past the neck of the fill spout.
I had to add one to my drinking water hose because the metal "male" end wouldn't go into the filler neck.
Good Luck, Mike
See my OP. there is a piece of tubing 12" long attached to the funnel.
Jack L
โMar-22-2014 04:57 PM
โMar-22-2014 04:35 PM
wannavolunteerFT wrote:
I bought a funnel in Lowes in the lawn mower section. Think it is for filling oil, etc on lawn mower. Has a long flexible hose type neck. stick the hose in the fresh water fill and you can turn funnel opening at at angle that you can pour into easily.
โMar-22-2014 04:28 PM
Good Luck, Mike
โMar-22-2014 01:54 PM
โMar-22-2014 01:24 PM
