Apr-27-2017 04:52 AM
Apr-27-2017 09:37 PM
katoom400 wrote:bobndot wrote:
Are you guys running the new heavy ply tires on the OEM rims ?
What are you doing about trying to match up the PSI ratings of the rims vs tires ? It seems like those 10 ply's are 80# psi ?
Are the rims rated at the same ?
how would you know what psi the wheel is rated for? I've never seen psi for wheels, just tires?
I found my Outback OEM aluminum wheels on etrailer and these are the specs they list:
Specs:
Rim dimensions: 15" diameter x 6" wide
Bolt pattern: 6 on 5-1/2"
Wheel bolt size: 1/2"-20
Pilot diameter: 4.25"
Offset: 0
Capacity: 2,830 lbs
Lifetime warranty against structural defects
https://www.etrailer.com/Tires-and-Wheels/HWT/TTWALS556655.html
Apr-27-2017 07:00 PM
Apr-27-2017 06:17 PM
Apr-27-2017 06:08 PM
Apr-27-2017 06:02 PM
Apr-27-2017 05:56 PM
Apr-27-2017 03:04 PM
Apr-27-2017 02:59 PM
Apr-27-2017 02:54 PM
Apr-27-2017 12:40 PM
Apr-27-2017 12:22 PM
DutchmenSport wrote:
Last year I replaced the tires on my Outback 298RE with Carlisle's (ST225 / 75 R15, Loan Range E, 80 psi, rated at 81mph ... all labeled right on the tire)
Even though I had only 1 bad tire (factory original), I replaced all 4 at the same time. Since the tires were installed, we've made 1 trip to Florida and 2 trips to South Carolina (from central Indiana), and several trips across Indiana. I keep the sun side of the trailer tires covered at home all the time. The shadow side is not covered.
I've had absolutely no problems with these tires. My speed is normally 60 mph, 65 at the absolute fastest, and I am very careful when backing that I'm not forcing side pressure on the tires by backing in sharp turns. Not always possible, but I try very hard to avoid backing sharp turns causing side force on the tires.
For the size of your trailer, these Carlisle's would do you very well. Get all 4 tires the same, whatever you do, and replace all 4 at the same time, regardless of how good the remaining tires look on your camper. Treat your tires the same as you would on your car or truck.
Apr-27-2017 11:09 AM
Apr-27-2017 11:08 AM
Lwiddis wrote:
You didn't cover your tires when parked at home? I cover up all four if stationary for more than two full days.
Apr-27-2017 08:25 AM
Apr-27-2017 07:58 AM
