Travel trailer
NancyLepri
I hsve a friend who owns a travel trailer. They took it camping when it was pretty cold in Michigan. Turned on the heat at night and the windows got condensation and dripped water down the walls. Is that normal?
10 REPLIES 10
GordonThree
crackin the windows and vent doesn't work for me, I guess I sweat too much, and my 150# dog is constantly panting too, so that's a lot of moisture in a 20ft trailer. A nice and quiet Frigidaire 90 pint dehumidifier keeps my cabin comfortably dry, and it gives off a nice amount of heat too, so the furnace runs less.
It takes a fair amount of power (about 800 watts), I can only run intermittently while on inverter, but on generator or shore power, it's on all the time.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
willi4nd
Could run a small dehumidifier but opening a window or running the bath fan works
New to the RV world and loving every minute of it.
2015 Nissan Frontier 4x4 6 cyl
2015 Trail Runner SLE 22
fitznj
Use an extra blanket and turn the furnace off at night; this has worked for us
in the past when camping in 20-30 deg F weather.
Gerry
fla-gypsy
Completely normal but not good
NancyLepri
Thanks for the info. I am going to have her get on this website. Love Rv.net!!
beemerphile1
Normal if they are breathing, washing, or doing other things that put moisture in the air.
Condensation works in this case just like the drops running down the side of a cool drink on a hot day. The moisture in the air condenses on the colder surface.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Rbertalotto
Is it just the windows or do the walls "sweat" also?
Could the windows be infilled with foam insulation panels to stop this?
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
temccarthy1
2oldman wrote:
It's normal for single pane windows.
But not normal or good for TT to drip down the walls!
Tim, Ramona and dog Scruffy
1982 Coleman Sun Valley PUP (retired)
2014 Keystone Bullet 285RLS Ultralite TT
2013 Ford Expedition XLT 5.4L Triton V8
Equalizer E2 hitch
2oldman
temccarthy1
Yes.. That is a chronic problem in a TT if you don't have air flow.. Was their heat forced air? That will help. If just static electric heaters, the moisture from a lot of people's breath, showers,and cooking will cause condensation and water on walls which can over time destroy the TT due to delamination inside the walls.. You always need to vent even when cold out by opening one or more roof vents to allow moisture to escape.
Equalizer E2 hitch
