Travel trailers and appliances
oldie64
Hi all I'm new here and new to owing a travel trailer with amenities such as propane appliances.
I just purchased a 2000 Keystone Cabana hybrid trailer, which has a 2 way fridge,furnace hot water tank, and roof top A/C unit.
I'm trying to find out if the 2 way fridge operating on electric has to level same as on propane to operate?
Also when is the water pump used when only using oncoard water supply versus city water connection.
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post your topic in the RV Forum which corresponds to the subject of your topic. Thank-you!
5 REPLIES 5
mobeewan
The fridge cooling system operates the same in either mode. Electricity or propane just provide the heat sources in order for it to operate.
bikendan
Yes the fridge has to be pretty level to operate on either propane or electric. Yes the battery has to be good to operate on propane. The mother board is ran by 12V
Yes The water pump is only used when you are pumping from the fresh water tank. You will have to fill the fresh water tank as well. The pump does not need to be on when you are hooked to city water. And the water heater will work on propane as well, but again the batter will have to be good. All propane appliances need 12V to work.
The AC will only work on shore power.
THIS^^^^^^^
1492
Moderator
Moderator
Moved from FORUM POSTING HELP AND SUPPORT
Terryallan
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
donn0128
Two way refer means 120VAC or propane. Remember most refers will still need 12VDC as control voltage. Water pump brings water from the on board storage tank to the faucets, toilet, etc. It does not work unless there is water in the tank first.
Might be a good idea to hire a mobile service tech to come spend a couple hours with you and teach you all about RV systems.
