โDec-01-2013 05:19 AM
โDec-24-2013 12:40 PM
wnjj wrote:bjbear wrote:
The GVWR is important, be because there are so many factors included in this rating, I believe there is some wriggle room. Nobody as far as I am aware regulates being over this rating (i.e. you won't get a ticket). However, just be aware, that if you are climbing a steep hill, at high altitude on a very hot day, you might have problems. Also, you have to think of the brakes going down hill as well.
I agree with the wiggle room thought. As for pulling a steep hill in the heat, towing at GCWR requires far more power than hauling a camper that puts you over GVWR. The engine doesn't care if it's onboard or being towed. Brakes are probably the real limit beyond suspension but consider it like a being at GVWR and towing a small trailer without brakes on it and drive accordingly.
โDec-24-2013 11:17 AM
โDec-24-2013 07:54 AM
Rrliljedahl wrote:
I bought the truck and took it to a scale.
2007 Classic Sierra 3500 Crew Cab, Long Bed, LBZ Duramax and Allison Transmission, 4X4, SRW
GVWR of of 9900 pounds
GAWR 6500 pounds
GAWR 4800 pounds
Michellin P265/75R16 LTX E2 (3400 pounds at 80 PSI).
With a 1/4 tank of gas and no one in the cab
the truck weighs 7060 pounds
front axle weight 4160
rear axle weight 2900
It would appear that leaving everything stock
My rear tires will let me carry a payload of (2x3400=6800-2900=) 3900 lbs putting my gross vehicle weight at 10960 which is over the stated GVWR of 9900 lbs.
Rear axle weight restriction as specified by GM would let me carry a payload of (6500-2900=) 3600 lbs. putting my gross vehicle weight at 10660 lbs which is over the stated GVWR of 9900 lbs.
Others have stated that the 11.5 AAM axle on this vehicle is the same as on a dually from that year and that the dually axle can take 9375 pounds which I am assuming has to do with the 2 extra tires in the rear. Redoing the calculations giving me a payload of (9375-2900=) 6475 lbs putting my gross vehicle weight at 14075 lbs which is way over the stated GVWR of 9900 lbs. I realize that I can not approach this even if I upgrade the tires and suspension.
What am I not understanding here?
โDec-24-2013 07:15 AM
โDec-03-2013 01:18 PM
โDec-03-2013 11:58 AM
Redsky wrote:
The axles are rated at 10,900 lbs. so the weak links are the springs and the tires. Easy to add helper springs and there are tires like the Toyo and Nitto Terra Grappler that support up to 3750 lbs. with the stock rims.
โDec-03-2013 11:49 AM
โDec-03-2013 11:39 AM
โDec-03-2013 08:21 AM
wnjj wrote:Rrliljedahl wrote:
I estimate that the crew cab long bed 4x4 diesel truck weighs 7100 pounds without the camper but I do not know how much of the weight is being carried by the rear axle.
Where do you go to figure that out?
Once I know that number I could estimate the rear axle weight with the camper.
If it helps your estimates any, I have a 2005 3500 SRW 8.1L ext cab 4x4 that weighs 4000 on the front and 2950 on the rear without the camper on. The diesel will only add to the front and the crew cab will probably add a little to both ends. I think this was with a 200# driver in the cab.
โDec-03-2013 08:15 AM
โDec-02-2013 10:08 AM
โDec-02-2013 09:52 AM
โDec-02-2013 09:04 AM
Ranger Smith wrote:
Well if you are estimating the camper to be 3500 lbs and tires rated for 3400 lbs there is a problem right there???
At least I think there is.
โDec-02-2013 05:58 AM
