Truck purchase fron ebay question/pre insection services
mattyj
I was all set on this F350 in Illinois on ebay, I spoke to the salesman and told him Im going to find a pre purchase vehicle inspection service to check out the truck. I find a service and the guy says he will do a compression test on the 6.0 liter diesel for an additional 50.00 for a total of 500.00 I think it was. Then I find out from work a compression test requires taking out the injectors and is alot of labor for 50.00. I did not pursue the truck and now I am looking locally only. Does anyone have any experience dealing with a inspection service? Maybe Im just being too cynical and dont trust anybody.Thanks Lou
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
6 REPLIES 6
kohldad
My SIL's father had an inspection done on a van in MD he was looking at. The guy reported back it had a little rust but was sound. When he went to pick it up, he found rust through in several spots. Our southern idea of rust is completely different than a mid-atlantic person. Jest is beware of persons and the difference of perspective.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Kayteg1
I drive 6l right now and I bought it long distance on ebay ๐Ÿ˜‰
But I bought it cheap enough to play with it.
Compression test on modern engines, especially diesels are huge jobs, so I usually settle for acceleration test and blowby test.
On 6l piston rings are pretty good, not so head bolts, head gaskets and EGR and oil coolers. Meaning compressor test can come perfect and you still can face $6,000 bills for new HG and new bolts.
Bulletproof oil cooler is like $1500 job.
Unless you are advanced DIY look farther.
I doubt you will find a shop who will do proper PPI on such animal for less than 4-digits.
jimh406
I would talk to the people over at ford-trucks.com
darsben
Actually I think $50.00 would be better spent getting an oil analysis
Traveling with my best friend my wife!
mattyj
Trackrig wrote:
I don't know of any way a compression test could be done on a diesel for $50. Have you ever looked under the hood on a 6.0? There isn't any room to get your hand down into anything in there without removing parts? I can't imagine the selling dealer letting someone start tearing apart the engine if there is no guaranteed sale.
I have a 6.0, stay away from them, I just paid $8,000+ last month to have the engine gone through.
To me the more important test is to check the oil temps going through the oil cooler to see what the variance is.
Bill
Bill, I see alot of ads saying the 6.0 was "bulletproofed" but none of them have documentation on it so as far as Im concerned its not, I dont know if a 6.4 is any better and that about my limit with the prices
Trackrig
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
