โNov-16-2013 05:45 PM
โNov-21-2013 01:35 PM
Majja13 wrote:I know this is off topic a bit, however, there have been a rash of RV battery thefts in our local storage yards. My brother is Po-Po in a local city and he told me that one night a couple weeks ago one storage yard got hit for over 50 batteries.
I switched to 6's this spring and have loved every minute of them. But I only did so as some Jack@$$ decided to steal my brand new 12's. So use what you have until they die and then make the switch.
โNov-21-2013 12:53 PM
Jayco23FB wrote:
I looked into changing my stock batteries last summer. I considered 6 volts as well as all the other 12 volt options. I ended up staying with the deep cycle 12 volt group 72s from Costco. My reasoning was everything in my camping set up is 12 volt already so if I had a battery failure I wouldn't be reduced to 6 volts. The other reason was the group 72 is easy to get, faily inexpensive and we have a Costco. Worked for me.
โNov-21-2013 12:14 PM
โNov-18-2013 06:12 PM
โNov-18-2013 05:33 PM
sluggo68 wrote:
well I just bought this new 2014 Springdale 266RLSS and have only had it out once with full hookups so I'm not really sure if these batts will fill the bill. I heard that 6vt golf batts are the best, but i'm not sure. My girlfriend like to just all the goodies (ie, tv, radio, etc.) in the TT when we camp so that's why I'm asking about the batts.
โNov-18-2013 12:06 PM
โNov-18-2013 04:48 AM
โNov-17-2013 05:26 PM
โNov-17-2013 03:42 PM
Gdetrailer wrote:WoodGlue wrote:
If you've got the bucks and want the best, get a couple of 6v AGM's.
WoodGlue
AGMs ARE not "better" in ALL cases, period.
They are a "specialty" battery which unless you NEED ONE of the "special advantages" you are simply throwing out you money.
One of the supposed advantages is you can recharge at a higher rate which allows you to use a gen for less time. This HAS been proved to be a wash, basically put AGMs might shorten your charging time by a few minutes.
Another possible advantage is can be used in any position and do not outgass which could allow for placing them INSIDE your living space. I for one however do not feel that this is a wise thing to do since AGMs like any other "storage" system which CAN store a considerable amount of energy CAN be subject to abuse which can cause catastrophic failure.
The real advantage of AGMs is allowing you to part with more money, get less capacity for the same physical size as a flooded lead acid.
โNov-17-2013 02:05 PM
โNov-17-2013 12:59 PM
โNov-17-2013 12:36 PM
โNov-17-2013 12:03 PM
โNov-17-2013 11:45 AM
