Sep-28-2014 11:02 AM
Oct-08-2014 07:42 AM
Oct-07-2014 10:09 AM
keymastr wrote:
In my opinion you should never tow anything over 3000# with a vehicle that has a unibody. A full frame SUV or truck makes a far better platform. Much stronger attachment points for suspension, hitch and drivetrain.
Have seen extreme cases where unibody vehicles would no longer close rear doors. Made for transporting passengers, not working like a truck.
Oct-07-2014 09:40 AM
Oct-07-2014 09:38 AM
Oct-07-2014 09:35 AM
Oct-07-2014 09:09 AM
mikeinaz wrote:
My current TT is a StarCraft 26BHS, loaded up it weighs in at 6000lbs.Dry weight is 5200lbs. The HTT we had was a 23' and weighed in at 5200lbs loaded up. 4500 dry. Again the Durango pulls both fine, I just need to work on getting a hint of sway out of the new one and it may be that the WDH was not adjusted correctly by the dealer when I bought the new one. The short wheelbase of the Durango does not help but we camp 10 times a year so for us, having a vehicle we really enjoy driving and that gets good gas mileage for our other 98% of life is a tradeoff we are ok with.
I have the R/T model and it has the blacktop package so everything is blacked out, grill, wheels and paint and I get more looks and comments on it than I do my Corvette! Again the new ones have the 8 speed transmission so that is also a plus. You could also look at getting one a year or two old to save some money(stay away from the 2011 models) but I think the hemi engine would serve you well for towing. They do have cylinder deactivation so once you get off the gas pedal (not applicable when towing)the eco light comes on and it cuts off 4 cylinders. I also have the awd so my mileage is a tad worse than say a 2wd. I get 22mpg on regular freeway driving and about 14 around town. Towing, everyone gets about 9mpg (gas) regardless of TV or engine. Hope this helps.
Oct-07-2014 08:57 AM
Oct-07-2014 08:56 AM
Oct-05-2014 10:56 AM
mikeinaz wrote:
I towed a 4800# trailer around w/ a Dodge Durango and it towed great. Mine is a 13 so it does not have the 8 speed trans, just the 6 but it does have the hemi and pulled that TT up hills fine. I recently went to a little larger and heavier TT and although the Durango pulls it fine, the short wheelbase does allow a bit of sway, I didn't have it on the shorter and lighter TT.
I LOVE our Durango and have had two friends w/ Highlanders actually buy a Durango after driving ours. Toyota's are great vehicle's just boring. The newer Durangos are a perfect size SUV and very reliable unlike the old ones. For us, we like it on a daily basis and although a truck would be better for towing, its a compromise for now I am willing to make. Check out the Durangos, the payload is 1200 lbs which would keep you well under your limits with hitch weight. Not sure how well that 6 cylinder will pull, as others mentioned you are not pulling a flatbed trailer and will have a lot of wind resistance to overcome, having the extra hp and torque will make pulling easier.Do get a WDH w/ sway control as well. Best of luck.
Oct-01-2014 08:22 AM
Oct-01-2014 06:55 AM
Sep-30-2014 07:09 PM
bmj11 wrote:bobvila wrote:
Hello from Vimont! Can you recall what kind of TV were pulling Lance 1985? Thanks
Yes , one was using a Jeep Grand Cherokee and the other one an Acura MDX
Booth seem happy.
I am from Duvernay , not really far from you. You can see my baby here
My Lance 1575
Sep-29-2014 07:14 PM
Sep-29-2014 06:06 PM
rexlion wrote::h
Your Highlander would do very well with one of these:
Escape Trailers,in B.C. - 21' model
