May-25-2015 02:30 PM
May-26-2015 10:57 AM
May-26-2015 10:27 AM
May-26-2015 09:18 AM
May-26-2015 08:59 AM
May-26-2015 08:52 AM
May-26-2015 06:09 AM
May-25-2015 08:00 PM
May-25-2015 06:50 PM
jdtrotter wrote:
It is a 12 volt compressor that is made by Dometic --- or they told us that Dometic recently bought out the company that makes them.
I can not read the model plate, but from the book it appears to be one of the CR models --- 50 or 65 and it does have a fan. We bought this as an extra and if it works correctly, it should be a good refrig. This is the second one they put in for us ---
The camper is brand new and we are still working out the bugs with the manufacturer. This will be our first long trip and on our way home, we will be stopping at the manufacturer to address another problem. So I guess we will have them check it out.
WE just wanted to know if the loud fan noise was normal because we don't want it to go out on our trip! It is not loud at all inside the camper, just outside.
Thanks
On edit, it is plugged into 110 right now, so we will see. WE do have a fantastic fan and it seems to run just fine with not strange noises.
May-25-2015 06:02 PM
jdtrotter wrote:
No slide out --- but thanks
May-25-2015 05:36 PM
towpro wrote:
it sounds like your refreg is in a slide out? When they put them in slide outs they don't have the vent on top, instead they have an upper and lower opening in the outside wall. They than put a fan on the back of the refreg to move air in the bottom vent and out the top vent when the cabinet gets warmed up. Yes they can make fan noise, but nothing you shouldn't be able to live with. See if the fan is not hitting on something. I have found if you open the lower vent, than use a digital camera to take pictures facing up you should be able to see the fan and if its hitting anything.
May-25-2015 05:33 PM
May-25-2015 05:30 PM
May-25-2015 05:00 PM
May-25-2015 04:59 PM
