VIDEO: No Bugs Allowed In The Truck Camper
Camper_Jeff___K
Nomad III
Nomad III
Turn your ceiling fan into a bug killing machine. An effective and easy way to use your Truck Camper or RV ceiling fan to remove bugs from inside your RV quickly and painfully (for the bugs that is). Fun to watch the little buggers get their butts kicked out and removes them quickly. No fly swatter mess to clean up. Some stragglers may need additional shoeing.
Some additional information:
A quick search yields that a bright white LED light will attract bugs.
Source.
Perhaps not as effectively as an incandescent light but in this case, the LED was the only light source in the truck camper and it was an intense, concentrated light source. That is why in this case it worked as well as it did.
Found this too.
Do fluorescent lights attract bugs?
In fact, a study to determine how the type of light bulb used affects the number of bugs attracted found that incandescent light bulbs attracted the most insects (with fluorescent bulbs coming in second), while LEDs, particularly those with a warm color temperature, attracted the least bugs.Sep 14, 2017
An incandescent light would work best if you have one.
Reading about bugs and light, Mosquitoes and blood sucking insects are attracted to infrared and most others to white-blue-violet bug zapper light if you want best results.
It's kind of turning into a science project. The object is turning your fan into an auto ejecting bug zapper/slicer/dicer!
4 REPLIES 4
Reality_Check
Nomad II
Nomad II
Don't laugh.. we carry a small rechargeable vacuum. Suck the bugs up and done with it.
'16 F550 CC, 4x4 with Link Ultraride air suspension, '18 AF 1150. Just so we can play with our snowmobiles, dirt bikes and fishing boat. And new 20' tag along...kayaks, bikes, mc's and extra water and food!!
fpoole
wow, kewl...
I'll see what can be done, the Gnats are driving me Knutts...
Thanks for the leads...
Hava good one..
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10โ€™ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow Nโ€™ Go, E-Bike
RS1 Buggy
frank
Pooles website
Camper_Jeff___K
Nomad III
Nomad III
Source.
Found this too.
fpoole wrote:
Well, sorta, hehehe... GNATS !!!
The ones that circle the kitchen light.... they stay there...
Tried various things, Bounce Laundry Sheets, AVon Soft skin around the lights..
No luck yet... next step would be bug Zapper...
I have used the fan foe Wasps.. for some reason they come in there, maybe cause of the smells being pushed out.. but like a warring blender, Thrashed....
but then you need to clean up the mess.. heheh..
Fun in the camper eh???
Edit: Ahhh soooo.. the key is to turn OFF the lights and use the flashlights... Might give a try..
Thanks...
Reading about bugs and light, Mosquitoes and blood sucking insects are attracted to infrared and most others to white-blue-violet bug zapper light if you want best results. It's kind of turning into a science project. The object is turning your fan into an auto ejecting bug zapper/slicer/dicer!
fpoole
Thanks...
Frank Poole
RS1 Buggy
frank
Pooles website
