Vintage TT needs stabilizing, but stumped
coachellacanuck
Recently acquired a 1964 Kustom Koach that I am converting to a mobile craft workshop to accompany our 2006 Copper Canyon Sprinter, both parked on our seasonal lot in Alberta.
She rides pretty low to the ground and came with 2 small jacks to put underneath but still bounces quite a bit when I walk around inside.
I am open to suggestions on how to stabilize her. Maybe better, bigger jacks that raise her higher? Plastic blocks under the jacks as well?
(Iโ€™d include a picture but I donโ€™t know how to do so with a URL.)
Thanks for any suggestions.
15 REPLIES 15
dodge_guy
coachellacanuck wrote:
dodge guy wrote:
Look for the small flip down style pop up camper jacks.
Not sure what flip down jacks look like. Scissor jacks?
Like these! Flip down jack.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
OleManOleCan
Chris Bryant wrote:
Jack stands, one at each corner. Crank the tongue down a bit, put stands under the rear, crank it up a bit past level, put stands under front,
Jack Stands are an economic solution.
A couple of years ago I used 4 on a Scotty. Worked very well.
Lowering the tongue raises the rear of the camper.
Insert jacks under metal and raise em till they are touching or nearly touching.
Raise the crank and it puts weight on the rear jacks.
Put jacks under the front, near the tongue, and lower the crank a little,
and your camper is sitting on 4 jack stands.
No rock and roll when you walk inside.
It's quick and easy to use Jack Stands.
Harbor Freight has em two to a pack. Decent price.
fly-swatter
If you're in Edmonton, head on over to Princess Auto or Canadian Tire. They will have lots to choose from.
2012 Ram 2500 Hemi
2012 Flagstaff 8524RLS
coachellacanuck
Thanks! Will search for similar in the area.
BarneyS
Not sure what jack stands refers to... those plastic โ€œLEGOโ€ blocks?
Inexpensive jack stands.
A bit better ones from Harbor Freight.
A variety from Northern Tool.
Barney ๐Ÿ™‚
Not towing now.
coachellacanuck
No, the kind of stands you use to change a tire at home.
Ah. So โ€œscissor jacksโ€! I wondered if those would work. Thanks!
afidel
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
coachellacanuck
coachellacanuck
coachellacanuck
Jebby14 wrote:
if shes seasonal maybe put her on blocks?
Like cement blocks? (Greetings from a Windsor native now in Edmonton!)
the_bear_II
Like Chris Bryant above...I used 4 jack stands placed under the frame near each corner and our TT was rock solid. It had a pretty beefy frame.
Some of the older TT used lightweight frames so you may need to place two more jack stands to support the middle.
Dick_B
RR ties or cement blocks under the frame.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
dodge_guy
Wife Kim
Son Brandon 17yrs
Dog Bailey
Chris_Bryant
-- Chris Bryant
