Warning light black water
rickhise
New to us
in bathroom we can check black h20,
gray an Batt status.
Seeing proper reading on all but
Black water.
After total dump showing 3 red dots?
Thoughts or things to try thanks
11 REPLIES 11
Ron3rd
rickhise wrote:
New to us
Black water.
Are you typing on a phone?
Equilizer Hitch
Honda EU2000
mike-s
rickhise wrote:
New to us
Black water.
Black H2O light
Never senses correctly
Forget it. Just look.
mbopp
proxim2020 wrote:
Try cleaning the tank with a tank wand. There could be something stuck on the sensors. The blast of water might be enough to knock off anything that may be stuck.
I'm a firm believer in a tank wand. Before I knew you could buy one I made my own.
2019 F250 XLT Supercab
Just DW & me......
SidecarFlip
Dennis12 wrote:
If you have to keep wipeing, it's full
Actually, if you get a wet butt, it's really full...lol
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Community Alumni
Not applicable
Dennis12
Dennis Hoppert
Old-Biscuit
Toilet 'Burps'....time to dump
Sink/shower draining slower....time to dump
Pump goes 'Burrrrrrrp'...should have added more water earlier
SidecarFlip
Best way and most foolproof way to check your BW level is look... right down the tirlet. OEM level gauges are useless. If the black gets too full, your tirlet won't flush and if the grey is too full, you shower won't drain.
pianotuna
Nomad II
Nomad II
The only indicator that works reliably is for fresh water.
Regards, Don
stickdog
Stuff stuck to the sensors in the black tank. In our last trailer I could dump, run the tank flush and the sensor read F and E, how could that be? Guess only the top of the tank was full and the bottom 2/3 was empty.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
2oldman
The gauges never work, not for the great majority of us. You could clean the tank with a pressure washer and they'd work for a while then quit again.
