Water coming into the slideout
tsmith5
Need some help! This past weekend, we had some nasty rain and water leaked into our camper from the floor of the bedroom slideout -- appears it was coming in from the tracking rail underneath the carpet, and then leaking all into the carpet inside the slideout. I checked the top and side seals and all appear to be in good shape, and for the life of me cannot determine how the water came in from the bottom as it did.
I've checked the outside - top and sides, and then from the inside all around - the only place it's coming in is from the bottom of inside the camper. I see no evidence of water on the outside bottom of the slideout.
Can you give me advice/ideas on where to check/investigate further?
Thanks all for the continuous help and support!
TW
10 REPLIES 10
pa_traveler
Be sure you have a tight seal so gaskets are keeping water out. One time same thing happened to me then I realized could have tightened up seal more.
Goldstalker
fatboy66 wrote:
Goldstalker wrote:
This is why I always leave my slide side just a but lower.
You mean you purposely put your slide out of level?? Doesn't sound like your slide motors would like that very much.
No it only takes a tiny bit to help, I know many other who do the same especially is leaving the slide open almost all the time in seasonal sites. Seals can fail anytime.
2007 GMC Sierra 1500 Crew Cab Z71 4X4 3.73
2013 CrossRoads Sunset Trail Super Lite 250RB
2-2012 Yamaha VX Deluxe
2012 Toyota Highlander
fatboy66
coolbreeze01
Sorry, but it sounds like it must be defective. Good luck.
2014 Sandsport 26FBSL
BillyandKris
I would want to ask what brand camper it is!!! But, I will refrain. We once had a TT that did this and it was an on-going problem from Day One. In and out of the shop a zillion times and never settled. Luckily it had no carpet and could be mopped up each time. In the end after much wailing and gnashing of teeth and studying the thing my husband came to conclusion it was "a design flaw" and could never be remedied. End of story and lesson learned. So very sorry for your issue and truly hope you can resolve yours. Good luck.
Goldstalker
donn0128 wrote:
That makes absolutely no sense? If your slide seals were properly designed by the manufacturer and are in good shape and actually sealing the opening there should be no moisture leaking in.
To the OP. I would suggest that you do a Seal Test after a thorough inspection of the seals. Any nicks or cracks in the seals can allow water in.
I completely agree but just do this for added assurance, I would rather have the water naturally run off than pooling on the slide.
donn0128
Goldstalker
tsmith5
It was extended. When pulling up the carpet pad it appeared it was coming through via the rail (tracking rail that I assume helps guide the slide in).
Thanks all!
TW
skipnchar
Was slide room retracted or extended when it leaked?
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
